Date: 27-03-26  Time: 21:44 pm
Author Topic: speedo stoped working  (Read 4068 times)
ernst
« on: 12 May 2012, 03:40:32 pm »
 :\ hi all,out on the bike today and doing about 60 ish and speedo just droped and hasnt worked since,any ideas guys .everything else  electric wise is ok?does it have a fuse for the speedo alone?or any common faults with speedo,s help!!
how.do@ntlworld.co.
Re: speedo stoped working
« Reply #1 on: 12 May 2012, 08:00:11 pm »
Speedo works from sensor on front wheel near side. Check the wire to sensor is okay. Mine went funny after I let a garage change the pads and they trapped the wire to the sensor in the process. Every since I have done my own service etc.
Dunky
« Reply #2 on: 12 May 2012, 08:53:31 pm »
More than likley it will be the ceramic drive dog inside the speedo sensor (one of the small tabs snapped off) you will get one for about £20 new.
Hope this helps.
Dunky..................
« Reply #3 on: 12 May 2012, 08:55:30 pm »
Hope this helps.
iam with you dunky...same thing happened with mine....easy to fit  :)
fazervic
« Reply #4 on: 12 May 2012, 09:35:29 pm »
£20.00 why did i get quoted £140.00  for a new sensor,  :eek
solorider
« Reply #5 on: 12 May 2012, 10:37:30 pm »
it could be the sensor but i would pop the wheel off and check the drive dog first,hopefully that is your fault and as mentioned the most common fault
« Reply #6 on: 13 May 2012, 07:07:41 am »
Hope this helps.
oops..........sorry GUNKY
« Reply #7 on: 13 May 2012, 07:10:14 am »
£20 quote will be for the drive dog which i think is the problem here,£140 could be right for the sensor knowing what yamaha prices are like  ;)
Captain Haddock
« Reply #8 on: 13 May 2012, 10:27:53 am »
Mine stops working occaisionally and I give it a whack and it works again, I like to call it 'percusive maintenence'.
Dunky
« Reply #9 on: 13 May 2012, 10:56:53 am »
Red98 you were correct the first time the name is Dunky mate someone thought it would be funny to alter it due to a remark that was said.
ernst
« Reply #10 on: 13 May 2012, 06:46:17 pm »
thanks for your suggestions chaps ,will have a look in the morning hopefully an easy fix,last time the wheel was off was about 500 milles ago when i got a new tyre,refitted the wheel myself so if the wires trapped only got me to blame,will let you know as soon as,cheers.
ernst
« Reply #11 on: 16 May 2012, 06:53:30 pm »
problem sorted :) it was the drive lugs snapped off,£17 from yamaha main dealer it looked like they are different with plastic ring and drive tabs but fit and worked ok, :lol happy days,thanks for all your help guys,
« Reply #12 on: 16 May 2012, 06:55:59 pm »
glad you got it sorted  :D
Dunky
« Reply #13 on: 16 May 2012, 10:39:29 pm »
Result  :thumbup
