Date: 10-05-26  Time: 20:44 pm
Author Topic: Sticky throttle  (Read 3752 times)
Oxygen
Sticky throttle
« on: 07 May 2012, 10:42:23 pm »
To answer my own question about a problem with a sticking throttle. It would not snap back when released.
I tried to oil the cable at first and this worked briefly but then it got sticky again. On the advice from a mate I removed the bar grip gave it a good clean and then sprayed some silicone on the handlebar and in the grip/throttle. This seems to have done the trick.
When I first looked inside the grip it looked very clean but it would seem that it was grease/dirt that was making it stick.
Might help someone with the same problem.
Lawrence
Re: Sticky throttle
« Reply #1 on: 07 May 2012, 10:49:32 pm »
Mine is like this, I'll have to give this a go at the weekend.  Thanks for the tip :)
Oxygen
Re: Sticky throttle
« Reply #2 on: 07 May 2012, 10:58:16 pm »
I put 3-in1 down the cables as well but it defo the grip.
SteveH41
Re: Sticky throttle
« Reply #3 on: 22 August 2012, 07:19:02 am »
Removed my grip and switch assembly last night as the starter button was a little more difficult to push than normal, cleaned it all out and thought that while it's off I may as well clean under the throttle grip.
Was quite a bit of dirt and general grime underneath which soon cleaned off with wire wool and Autosol, little bit of silicon spray on both the inner grip and bar, reassembled and all feels good, will give it a ride out today and check if weathers ok.
Re: Sticky throttle
« Reply #4 on: 22 August 2012, 08:54:44 am »
sticky throttle is mot fail........great tip  :D
Lawrence
Re: Sticky throttle
« Reply #5 on: 22 August 2012, 09:19:20 am »
Mine turned out to be the bar end mirror was done up against the end of the grip.  Since I took them off it's been fine and since one of the inserts is missing I've never got around to putting any weights on since removing the mirrors.
ade the blade
Re: Sticky throttle
« Reply #6 on: 22 August 2012, 10:14:32 am »
so the motto is........apply marmite sparingly when lubing up ya throttle boys and girls !! :lol :lol :lol :lol .
Re: Sticky throttle
« Reply #7 on: 22 August 2012, 10:55:04 am »
ooooooooooooooooooooahhhhhhhhhhhhhhhhhhhh.....not used marmite before......not everyone will like it ;)
