Date: 15-05-26  Time: 22:13 pm
Author Topic: Fazer 1000 high beam issue  (Read 18614 times)
Tommy666
« on: 22 June 2024, 06:01:11 pm »
Hello I have a problem with my Fazer and wonder if anyone can help me out, the lights are permanently on with no switch provided to turn them off , when I start the bike and use either the flasher or high beam switch the rev counter drops briefly to zero and all the warning lights on the dash illuminate for a couple of seconds then normality is returned, however it only performs this unusual trick on first using the flash/dip switch 🤷‍♂️ I have never noticed this issue until I took it for the MOT and the tester pointed it out to me , I should say the bike passed its test as all lights work normally, a mate has the same bike and has the same problem, hopefully someone will have had this issue and found the solution
Regards Ian
old son
Re: Fazer 1000 high beam issue
« Reply #1 on: 23 June 2024, 05:32:44 pm »
I think there is a multi cable connector to the Speedo housing. That might not be making a good connection. Try giving it a good clean. Also check your earths.
Tommy666
« Reply #2 on: 24 June 2024, 08:08:35 pm »
Hello, my mate and me have had every block connector apart and they were all clean as a whistle , however it does seem that when high beam is used there’s a big voltage drop 🤷‍♂️.
Thank you for your reply 👍
Gnasher
« Reply #3 on: 25 June 2024, 11:28:19 am »
There's a short in the positive circuit somewhere, it's probably in the loom as it goes around the headstock or in and around the head light unit. It's could also be a connector. Being clean doesn't mean there's no shorts.   ;)
