Date: 01-05-26  Time: 23:59 pm
Author Topic: What protection should I but on my battery contacts  (Read 16799 times)
« on: 19 June 2024, 01:13:39 pm »
As per the title its a new battery and I have some servisol silicone grease, its says for switch contacts, ignition systems but it also says "high insulation properties".Eh - I dont get it why is it used on contacts if it has high insulation properties.Should I not put anything on, or maybe copper grease, vaseline or the servisol. I am only talking about a very fine smear. Or I also have some ACF 50 I could use.
Grahamm
  • Global Moderator
Re: What protection should I but on my battery contacts
« Reply #1 on: 19 June 2024, 02:36:35 pm »
From what I understand, you secure the contacts and *then* put the silicone spray/ Duck Oil/ WD-40/ ACF-50 over them to keep water away and help prevent corrosion.
BBROWN1664
« Reply #2 on: 19 June 2024, 06:47:22 pm »
:agree:
« Reply #3 on: 20 June 2024, 09:49:29 pm »
Ok thanks both for clearing it up for me.
agricola
« Reply #4 on: 21 June 2024, 05:59:50 pm »
I'd brush them with ACF50 before fastening up. I've been using it for around 15 years and found it exceptional at corrosion prevention
« Reply #5 on: 21 June 2024, 07:37:01 pm »
Yep that ACF50 is very good stuff
