Date:
19-12-25
Time:
15:15 pm
Home
Media
old - Fazer Owners Club - old
FZS600 Fazer
brake lines
« previous
next »
Print
Pages: [
Author
Topic: brake lines (Read 2185 times)
Robfzs
DAS Born Again
brake lines
on:
30 April 2012, 08:40:01 pm »
yet another thread on them !
http://www.ebay.co.uk/itm/300612944377?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
they worth getting ?
Logged
swem
DAS Born Again
Re: brake lines
Reply #1 on:
30 April 2012, 08:49:01 pm »
hi rob i put hel brake lines from bikebitsni and a set off ebc hh pads the difference is night and day best money i ever spent
Logged
Naughty Corner
GP Hero
Re: brake lines
Reply #2 on:
01 May 2012, 05:28:08 pm »
Quote from: Robfzs on 30 April 2012, 08:40:01 pm
Yep, that said these look like older stock and not coated, you should be able to get newer coated lines all colours for about the same price or the trick shadow lines
http://www.demon-tweeks.co.uk/motorcycle/brake-lines/goodridge-motorcycle-shadow-brakeline-kits
They are really well finished got them on GSXR and for under £50 last year.
Logged
ddtwelve
WSB Pack Hound
Re: brake lines
Reply #3 on:
01 May 2012, 08:28:16 pm »
race or standard front lines?/?
Logged
Naughty Corner
GP Hero
Re: brake lines
Reply #4 on:
01 May 2012, 09:44:33 pm »
Race lines are simpler only two lines and do away with the three union so should be easier to bleed, some suppliers charge a slightly higher price for standard lines the choice is yours really.
Logged
HarryHornby
GP Hero
Re: brake lines
Reply #5 on:
02 May 2012, 09:32:21 am »
How easy are these to fit yourself? I'm no mechanic, but I've balanced the carbs using the great guide on here, replaced rear brake pads, checked and adjusted spark plugs, air filter, oil and filter change, basic stuff really.
Logged
Dave48
GP Hero
Re: brake lines
Reply #6 on:
02 May 2012, 09:52:31 am »
Fitting braided lines is not difficult-just need to be methodical. Recommend you fit twin lines from front m/cylinder & do away with union piece-ie one line to each calliper. Use new crush washers-usually supplied in the kit. Dont overtighten union bolts as your going steel into alloy-check torque figs.Bleeding can be a pain but patience will get you there whether you use tube& jamjar or a proprietary bleeder (I have a Mityvac & its ace!). Dont forget to protect all your lovely paintwork from brake fluid spills, Good luck. One of the best mods Ive ever done to ANY bike Ive owned
Logged
Print
Pages: [
« previous
next »
FZS600 Fazer
brake lines
SMF 2.0.19
SMF © 2011
Simple Machines
Simple Audio Video Embedder
SimplePortal 2.3.7 © 2008-2025, SimplePortal
Crushing Theme by
Diego Andrés
XHTML
RSS
WAP2
