Date: 27-03-26  Time: 10:28 am
Author Topic: indicators have stopped working !!  (Read 4704 times)
fazervic
« on: 30 April 2012, 06:38:36 pm »
i have had the indicator switch, indicator relay checked still no joy  :(  there is main relay also which i will try , but headlamps,horn,work,
bikemad62
Re: indicators have stopped working !!
« Reply #1 on: 04 May 2012, 07:09:00 am »
Try looking under the seat at the back. A small white fuse holder on the left hand side (as you sit on it) That is the indicator / hazard light fuse. 10 amp i think hope this helps.
« Reply #2 on: 05 May 2012, 08:21:44 am »
mine have been playing up......sometimes they work...sometimes they dont...sometimes they work...sometimes they dont...sometimes they work...sometimes they dont...sometimes they w.................. :rollin :rollin :rollin
cant believe iam the only one who wanted to put that on here  ;)  ,good luck sorting your problem
fazervic
« Reply #3 on: 05 May 2012, 02:05:10 pm »
:lol :lol
all sorted broken wire !!
« Reply #4 on: 06 May 2012, 07:49:04 am »
well done mate....back on the road again  :D
matthewoswald
« Reply #5 on: 17 May 2012, 11:49:46 am »
hello
yeah I have an intermittently working left indicator! any ideas? right is OK.
I guessed it could be a dodgy electrical connection? help!
« Reply #6 on: 17 May 2012, 12:44:49 pm »
Hi Matthew, and welcome to the forum.
Assuming the bulbs haven't freakishly failed at the same time, have a look in the connector box under the tank. Check all the connectors that go to the left handlebar for corrosion. If they're all good and tight it may be poor contact in the switch itself... usually best to dismantle it, but squirting some WD40 in through the drainage holes underneath and giving the switch some exercise might clear it if you're lucky.
matthewoswald
« Reply #7 on: 17 May 2012, 03:47:15 pm »
Hi and thanks for the reply
yeah the bulbs are fine because they work with the hazard warning light and they occasionally work with the indicator.
I'll check those areas as you suggest and I'll also give some WD40 a try and cross my fingers.
many thanks
Matt
