Date: 16-05-26  Time: 15:11 pm
Author Topic: Throttle cable routing  (Read 9122 times)
Tortoise
« on: 07 January 2024, 03:36:15 pm »
If anyone can please help. Had the throttle cables out months ago, before finally getting round to valve adjustment and ais removal. Now its time to put back together,. when fitting the coolant pipes that go into the cam cover. The piece at the top which the throttle cables cross, do the throttle cables go over or under the tube/hose. Or does one go over and one under neither really looks right . Any help much appreciated.
b1k3rdude
Re: Throttle cable routing
« Reply #1 on: 07 January 2024, 06:28:52 pm »
@Gnasher will correct me if Im wrong, but  think they go over those pipes and then through a guide loop bolted to the righthand side of the steering column and then info the handlebar assembly.
NitramA
« Reply #2 on: 07 January 2024, 07:07:26 pm »
If you go to the download section of this forum there’s a FZS1000 Service Manual with diagrams showing the correct cable routing.
Gnasher
« Reply #3 on: 08 January 2024, 02:13:33 pm »
Sounds about right to me.  Make sure you go under the frame cross member, which is above and forward of the where the cables joins to the carb linkages.  Over the top of the engine and over the front rad hose, up through guide loop, up through the back of the fork yokes, around the right fork tube and up to the handle bar and throttle housing.
Once connected and adjusted, start the bike and with the engine at idle, turn the bars fully left and right.  If the revs rise/fall the cable is either incorrectly routed/adjusted or both.  There should be no change is rpm and you should have full throttle movement/return at full lock both sides.
Tortoise
« Reply #4 on: 08 January 2024, 02:23:35 pm »
Many thanks for that Gnasher it was just the part whether over the coolant pipe or under. I can now fit cables over the top knowing its the correct way.
Gnasher
« Reply #5 on: 08 January 2024, 04:02:25 pm »
This my help you further, courtesy of PATs page. If you know what you're looking at the throttle cables are obvious.
https://www.cartestsoftware.com/fz1/images/cscarb12-34screwdriver.jpg
NitramA
« Reply #6 on: 09 January 2024, 04:17:09 pm »
What a complete pr#@t! Just noticed what bike it’s for. Only excuse I have up is that I had man flu when I posted 😳😳😳
