Date: 15-05-26  Time: 18:07 pm
Author Topic: Clutch  (Read 7666 times)
fatbloke62
Clutch
« on: 13 August 2023, 11:19:54 am »
Hi foccers not posted for a while but I need some advice if possible, I've noticed of late when the bike is idling the clutch is silent, pull in the lever and it starts rattling ,something I have never had before any ideas ,cheers
Gaz66
Re: Clutch
« Reply #1 on: 08 September 2023, 09:33:11 pm »
Hi..
Depends what u call a rattle, 1 mans rattle is another mans rumble.
If it concerns u, it needs stripping for a bit of inspection.
More than likely a wear issue, often the springs get weak in the clutch hub & rattle like crazy, this can affect most bike clutches, but could be the dreaded bung that detached from the shaft end, never seen it myself, but it does happen, I would have thought any foreign body rattling around in a clutch assembly would either lock the clutch up or stop it releasing.
Spanners out time. :thumbup
Gnasher
Re: Clutch
« Reply #2 on: 12 September 2023, 01:04:37 pm »
If there is a noticeable rattle/rumble when the clutch is pulled, that would suggest basket bearing and/or worn basket.  Could also be push rod assembly wear.
b1k3rdude
Re: Clutch
« Reply #3 on: 14 September 2023, 05:13:06 pm »
or worn basket.
This is a common point of wear, that depending on the amount of wear can only be resolved by replacing the clutch basket with a new or less worn one.
