Date: 09-05-26  Time: 07:31 am
Author Topic: ais removal  (Read 6488 times)
Dodsy
ais removal
« on: 26 June 2023, 03:58:35 pm »
hello everybody recently removed the ais on my fazer 1000 took it for a proper run today.its got a ivans kit on it plus a akraphovic pipe not running smoooth on constant throttle and the end of the pipe is black with soot. ran perfect until i did  the ais also i use shell vpower thanks
PieEater
Re: ais removal
« Reply #1 on: 26 June 2023, 04:47:49 pm »
Exactly what did you use to blank off and seal the exhaust port stubs, airbox and carb intake boot?
Dodsy
Re: ais removal
« Reply #2 on: 26 June 2023, 08:20:54 pm »
ais  removal kit from usa
PieEater
Re: ais removal
« Reply #3 on: 27 June 2023, 09:30:09 am »
Holeshot or Ivan's? Both use different methods for the exhaust ports and my Holeshot kit didn't come with any caps for the airbox or intake boot. Holeshot you need to use extreme high temperature silicone to seal the caps, I bought a genuine Yamaha cap and clip for the carb and had to find a cap for the airbox but made sure this was airtight. If you can provide some more information about exactly what you used it would be easier to help you but I'd suggest you've not properly sealed the system.
Gaz66
Re: ais removal
« Reply #4 on: 30 June 2023, 07:56:29 pm »
Hi ...Bit more info required so we can help further.
Did you install the Ivans jet kit?
If not then you've no proof it's actually been fitted without pulling carbs & stripping em.
 :thumbup
Dodsy
Re: ais removal
« Reply #5 on: 01 July 2023, 08:24:20 am »
ivans kit exhaust sealer around the threads  and silicone sealing boots on the cards and airbox intake. ivans carb tuning kit was fitted to the bike before i purchased it many thanks
