Date: 22-04-26  Time: 11:46 am
Author Topic: Hi all cyclinder 1 issue  (Read 2840 times)
Chriscliffy
« on: 15 March 2023, 10:16:03 pm »
Hi
Im having a issue with my 2000 fazer 600 its been sat for about 2 years now. I have decided to make it a cafe racer. Went to start it up last week and its running on 3 cylinders number 1 is not firing. Changed spark plugs new coil carbs out and cleaned still only running on 3 any advice welcome. Thanks chris
Chriscliffy
Cylinder trouble !!!!
« Reply #1 on: 16 March 2023, 07:18:29 am »
My fazer has decided that it would like to be a triple. Cylinder 1 will not run at all i have cleaned out carbs, new plugs new coil no luck. Please help.
BBROWN1664
Re: Hi all cyclinder 1 issue
« Reply #2 on: 16 March 2023, 08:09:37 am »
If you have a good spark then its got to be fuel related. Does the cylinder "kick in" when you get the revs above 4-5K? If so, you have a blocked idle jet. If not, both jets or the fule bowl needle are blocked. Either way, its a carbs out and clean job. Not uncommon with modern fuel unfortunately.
Chriscliffy
« Reply #3 on: 21 March 2023, 09:00:17 pm »
Sorry not getting back had carb out again i didnt see anything block but cleaned everything and i will get them back in this weekend. Cheers
