Date: 02-05-26  Time: 11:17 am
Author Topic: Fork it! (Upper fork bushing)  (Read 3840 times)
CamSIXFIDDY
« on: 20 July 2022, 05:06:00 am »
Hey peepz
Im replacing the oil, seals and bushings in the forks of my '02 1000, i have done seal replacements and rebuilds more times than I ever should have had too (wheelies can get expensive) with all my bikes over the years without many issues UNTILL NOW!
when putting the forks back together and driving the seals home, the outter/upper fork guide bushing is not going into its recess in the fork lower properly, which obviously stops me from setting the seal properly and installing the retaining clip. :wall  Everything seems straight and square it just will not fit. The bushing was even put in the freezer the help with installation.
The bushes were ordered from brook suspention (NOX brand), far as im aware the parts are correct and are the new spec bushes that supersede yamahas original spec.
Lower/Inner/slide BUSHING
Thickness 1.00mm
Outer diameter 43.70mm
Inner diameter 41.70mm
Hight 20.00m
Upper/Outter/guide BUSHING
Thickness 2.00mm
Outter diameter 43.00mm
Inner diameter 47.00mm
Height 12.00mm
Anyone had an issue with these sizes or brand.
Mark YPVS
Re: Fork it! (Upper fork bushing)
« Reply #1 on: 20 July 2022, 04:22:26 pm »
Just had the same issue on my Gen 1 , i used Allballs fork kit and couldn't get the top bush to seat all the way same as you, so i ordered gen yam stuff , then a set of forks came up on ebay cheap so i brought them , just changed the oil.
once the bike is together i may attempt redoing the ordinal forks or just sell the lot (forks in bits, gen yam seals & top & bottom bushes)
i have also rebuilt many sets of forks over the years but i did admit defeat on these !! :lol :lol
Mark
Gaz66
« Reply #2 on: 05 August 2022, 10:44:02 pm »
Had same issue yesdi.
K-Tech bushes are tight as fook, had to file 0.25mm from bush gap to get enough tolerance to get em in.
b1k3rdude
« Reply #3 on: 06 August 2022, 09:22:51 am »
Well as Gnasher would presumably say, thats what you get for not getting genuine.
Gaz66
« Reply #4 on: 06 August 2022, 11:06:10 am »
Yes agreed.
But you'd expect better from a suspension specialist like K-Tech.
I'll try genuine next time if I live long enough to wear these foccers out  :lol
b1k3rdude
« Reply #5 on: 06 August 2022, 03:04:29 pm »
Yes indeed, you should feed that back to them.
Trebus
« Reply #6 on: 06 August 2022, 09:49:57 pm »
Had a similar experience with the K-Tech bushes. Did manage in the end but bloody tight! Was reserving judgement as by eye they looked almost identical to the orignals.
Anyway, they went in and forks work as well as a standard dampened set of FZS100 forks can do!
Dodsy
« Reply #7 on: 12 August 2022, 09:29:02 pm »
I ordered bushes from a seller on eBay far too think apparently there was a huge batch wrongly made they were replaced with the thinner correct ones try xanado  eight on eBay they sorted me out
