Date: 25-04-26  Time: 15:21 pm
Author Topic: throttle sticking  (Read 3696 times)
dilboy
throttle sticking
« on: 13 July 2022, 06:28:04 pm »
Hi all
Bike failed mot on throttle sticking, replaced the cables ,W.D the spring on the carbs
Still sticking.
any ideas amigos ?
FazThou
Re: throttle sticking
« Reply #1 on: 13 July 2022, 08:34:00 pm »
Are they routed correctly ?
Does the throttle feel free on the bars ?
« Reply #2 on: 16 July 2022, 01:38:55 am »
Could be corrosion of the butterfly shaft. Not easy to lubricate unless you remove the carbs. I have seen it on a few fazers, especially ones that are out in all weathers and used all year round
BBROWN1664
« Reply #3 on: 16 July 2022, 11:10:47 am »
disconnect the cables and determine if the problem is with the carbs or the cables/grip
Have to fitted heated grips? Are the fowling the switch assembly?
Is the bar end weight catching on the end of the grip?
