Date: 11-05-26  Time: 09:10 am
Author Topic: Carb issues  (Read 2941 times)
dilboy
Carb issues
« on: 16 April 2022, 03:17:25 pm »
Hi all
So I've re connected my fuel tank to the carbs ,turned the bike over ,then petrol starts flowing out of an overflow pipe on the carbs.
[size=78%]all the pipes are on correctly[/size]
Any ideas what to look for.
cheers
BBROWN1664
Re: Carb issues
« Reply #1 on: 16 April 2022, 04:57:36 pm »
a stuck float. try giving the bowl a good tap
Trinafzs
Re: Carb issues
« Reply #2 on: 20 April 2022, 08:49:09 pm »
Is it possible to remove a carb float bowl without removing the carbs in full? I have a similar problem with petrol pouring from one carb and the others seemingly working as required!
BBROWN1664
Re: Carb issues
« Reply #3 on: 20 April 2022, 09:10:25 pm »
it is, but its not easy. Putting the bugger back on again is even harder
Sherb68
Re: Carb issues
« Reply #4 on: 23 April 2022, 12:51:23 am »
Hi i had a similar problem with my carbs,after removing umpteen times and still leaking fuel i found the problem to be the seals on the link pipes inbetween the carbs hope this helps
