Date: 19-12-25  Time: 19:40 pm
Author Topic: Starter not working  (Read 4160 times)
festerbestertester
Starter not working
« on: 07 January 2022, 02:29:51 pm »
Came to start the bike this morning and there is no noise from the starter motor or the fuel pump. The battery is fine, fuses okay and lights work. Would appreciate any advice.
2002 fzs600
Mark YPVS
Re: Starter not working
« Reply #1 on: 07 January 2022, 03:23:22 pm »
Have you checked the red "engine on/off" button on the right hand switch?
Mark
festerbestertester
« Reply #2 on: 07 January 2022, 04:36:57 pm »
Will open up in the morning and test
Weather permitting (snow!)
Thanks
« Reply #3 on: 07 January 2022, 05:47:43 pm »
Sounds like the kill switch is "off"
If the oil light comes on when you press the start button, this just about proves the kill switch is the issue.
If the oil light doesnt come on, it could be the starter button but as you dont have the fuel pump priming either, my money is on the kill switch.
festerbestertester
« Reply #4 on: 07 January 2022, 07:19:45 pm »
Thanks. Just hope it’s dry tomorrow and I will investigate
Slaninar
« Reply #5 on: 08 January 2022, 08:00:29 am »
Someone correct me if it's a stupid idea, but I also think it might be the kickstand switch. Instead, or along with the kill switch. It's worth checking at least.
That thing cuts off the electricity when the kickstand is down - there's a small switch that the kickstand presses when it's retracted (if memory serves me correctly).
The switch shouldn't work when the bike is in neutral, only when it's in gear.
festerbestertester
« Reply #6 on: 08 January 2022, 12:23:31 pm »
Bike was in neutral. When I switch the ignition on the neutral light the aisle light charger light oh come on but the charge light and I light go off immediately neutral stays on. Hopefully it will stop raining soon and I can check the switch. Do wish I had a garage!
festerbestertester
« Reply #7 on: 08 January 2022, 02:01:26 pm »
Opened the switchgear sprayed with a electrical cleaner put back still nothing.
Supposed to be a better day tomorrow and I can get a meter on the switch
festerbestertester
« Reply #8 on: 09 January 2022, 09:34:44 am »
I have checked and got continuity with the switch. Any other ideas appreciated
« Reply #9 on: 09 January 2022, 10:36:26 am »
The bike may well be in neutral, but the switch shorts out due to corrosion and thinks it's in gear.  I'd also check the clutch switch on the handle bar ;)
Failing that start looking at starter relay, or the starter itself.
festerbestertester
« Reply #10 on: 09 January 2022, 11:53:43 am »
I have no continuity with the side stand either up or down.
 Is it goosed?
« Reply #11 on: 09 January 2022, 12:19:09 pm »
 Is it goosed?
Sounds like it, is the plunger moving?  If not sometimes you can free the plunger off with WD or such like, but it's likely it's very corroded internally.  Loop the switch out which will get the bike running and replace the switch.  ;)
festerbestertester
« Reply #12 on: 09 January 2022, 12:50:00 pm »
New unit ordered. Will try bypass if it stops raining
« Reply #13 on: 09 January 2022, 04:30:11 pm »
 Is it goosed?
Trace from the switch back up the frame to the loom where there should be a plug and disconnect that.
Check continuity to the switch on its own, also try starting without the switch connected and then with a connection across the loom plug.
festerbestertester
« Reply #14 on: 12 January 2022, 01:15:30 pm »
Solved. Intermittent cut-off switch,
 corroded starter switch, and side stand switch.
« Reply #15 on: 12 January 2022, 04:11:21 pm »
 8) ;)
midden
« Reply #16 on: 08 February 2022, 09:23:02 am »
pull the main fuse and reinsert (if not blown).  worked for me the other day
« Reply #17 on: 08 February 2022, 06:18:18 pm »
There is no charging light on the Foxeye 600. If it's the red light in the tacho you are seeing, thats a coolant high temp light.
Side stand switch is repairable as you can open it and clean it.
Side stand switch replacement/repair is an engine out job or you could follow instruction here   https://foc-u.co.uk/index.php?action=downloads;sa=view;down=66    and not take the engine out  :lol
festerbestertester
« Reply #18 on: 10 February 2022, 07:03:07 pm »
All sorted. MOT passed
Slaninar
« Reply #19 on: 11 February 2022, 05:54:20 am »
Woohooo!
Fazers are like good wine - they mature with age, and get better!  :)
