Date: 25-05-26  Time: 05:36 am
Author Topic: Gear indicator  (Read 4676 times)
Dodsy
Gear indicator
« on: 05 December 2021, 09:04:54 am »
What’s the best gear indicator for a 2005 Fazer 1000 and how easy to fit thanks
Captain Haddock
Re: Gear indicator
« Reply #1 on: 05 December 2021, 12:16:41 pm »
If they are still being made the multi-gauge that replaces the fuel gauge is a tidy way of doing it and gives lots of other functions as well, but the setting that shows your top speed when you come to a halt is very bad for goading the throttle hand.With the addition of a £5 gps module is gives a gps speed as well and can act as a speedo healer if you are on different tyre/sprocket combos.Christian from on here was making them.
robbo
Re: Gear indicator
« Reply #2 on: 05 December 2021, 01:19:41 pm »
If you want just a gear indicator, then the Gi Pro by Heal Tech is straight forward to fit, works first time and all the time. Choice of colours. For your bike you need the X type with the GPX-Y01 harness, unless the spec has changed in the last few years. Plenty of info if you use the Search feature.
Kenbob
Re: Gear indicator
« Reply #3 on: 08 December 2021, 11:17:24 pm »
The heal tech one also doubles as a shift light for peak torque or rpms, which is nice.
CatalinU
Re: Gear indicator
« Reply #4 on: 16 January 2022, 09:24:28 am »
Healtech is top notch, easy to fit and it's perfect
beuleux
Re: Gear indicator
« Reply #5 on: 23 January 2022, 10:42:24 pm »
Just looked up healtech, I wouldn't mind one but I'm a bit OCD about cluttering up the clocks, might stick some on the bars 🤔
robbo
Re: Gear indicator
« Reply #6 on: 24 January 2022, 11:48:18 am »
I'd certainly rather have it behind the clocks out of the way, but in comfortable line of sight, rather than stuck on the handlebars.
