Date: 11-05-26  Time: 12:41 pm
Author Topic: Help with FZS600 clutch please  (Read 2709 times)
VinceFZS600
« on: 13 November 2021, 02:36:50 pm »
My clutch is really hard to pull and spoils the ride. The clutch cable is fine & the housing for the cable mechanism is light as a feather, retracts as I guess it should.
Do I need to fit a different clutch or springs?
Any help greatly appreciated.
Many thanks, Vince.
Re: Help with FZS600 clutch please
« Reply #1 on: 13 November 2021, 05:57:54 pm »
Three reasons for a heavy clutch on the 600
1, Cable routed incorrectly, putting a sharper than acceptable bend on it.
2.Poor spurious cable the OEM is best .3.The worm gear bearings in the Sprocket cover are shot4. Someone fitted EBC  Heavy duty springs to the clutch.
Wear on the clutch could cause it but would be uncommon.1 and 2 would feel fine with the sprocket cover detached, but would not work well under load.
I would say check the cable route first as per the service manual.
Put in an OEM cable and grease the worm gear in the sprocket cover. There is a how to doc in the downloads section on greasing the worm gear bearings.
If still a problem, replace the springs in the clutch with OEM.
psyfi_1
« Reply #2 on: 22 May 2022, 11:18:09 am »
always use standard oem springs also if clutch is hard to pull...... one did you just do a clutch plate change if so.... did you take final drive cover off and..? if you didnt the clutch basket is not it properly and needs re-seating
