Date: 17-04-26  Time: 06:52 am
Author Topic: 400 manual  (Read 24840 times)
Billy Sprocket
400 manual
« on: 15 October 2021, 12:44:00 pm »
Hi everyone, thanks for letting me join :)
I recently bought a 400 Fazer Japanese import and I can't find a manual for it at all anywhere, I've got the 600 manual but nothing under the tank seems to match up and i need to get the carbs off to clean them could anyone help point me towards a manual for it please?
BBROWN1664
Re: 400 manual
« Reply #1 on: 15 October 2021, 04:07:41 pm »
Have you looked in the downloads section of this forum?
https://foc-u.co.uk/index.php?action=downloads;cat=7
Billy Sprocket
Re: 400 manual
« Reply #2 on: 15 October 2021, 05:04:04 pm »
Yes I've looked in there and it's all either wiring diagrams, parts catalogues, paint codes, other models or written in Japanese. I need a Haynes manual or something similar but they just don't seem to exist anywhere for some reason.
BBROWN1664
Re: 400 manual
« Reply #3 on: 15 October 2021, 09:18:38 pm »
The FZS400 was a bike made for the Japanese market and only imported into english speaking countries in small numbers so people like Haynes wont do a manual as the market isnt there to sell the manuals.
IIRC the main difference under the tank between the 400 and the 600 would be the lack of fuel pump. Carbs out should be a similar job on both bike though.
Billy Sprocket
Re: 400 manual
« Reply #4 on: 18 October 2021, 10:45:17 am »
Ok thanks for the info, I've had a go at it following the 600 manual but once the tank came off everything was completely different so I might just have to give up and take it to a garage
BBROWN1664
Re: 400 manual
« Reply #5 on: 18 October 2021, 12:14:52 pm »
post some pictures and tell us what the actual issues are , we may be able to help still.
FazThou
Re: 400 manual
« Reply #6 on: 18 October 2021, 07:16:20 pm »
As bbrown1664 said above, get some pics up from under the tank and we can guide you through it.
Why do you think you need to get the carbs off?
Billy Sprocket
Re: 400 manual
« Reply #7 on: 19 October 2021, 01:43:07 pm »
thanks :) i've got a lot going on at the moment including another bike to rebuild but hopefully i'll be able to get the tank off at some point and put some photos here.
I need to clean the carbs out, the bike was sat in a garage for around 18 months before i bought it and it revs happily enough but the tickover is lumpy and temperamental, if i stop i have to keep playing with the throttle to stop it from cutting out.
BBROWN1664
Re: 400 manual
« Reply #8 on: 19 October 2021, 05:11:27 pm »
Sounds like the carbs could need a clean - stick some photos up and we can help guide you through
Re: 400 manual
« Reply #9 on: 19 October 2021, 08:33:01 pm »
Removal of the carbs is almost the same as the 600, just remove the plastic tray over the carbs which holds the coils.
Remove the two plastic rivets which attach it to the frame and pull out the drain hose with it.
Take note of how it locates first, don't lose the rubber funnel attached to the tray which funnels any fuel or water from the top of the tank (same as the 600).
400 Carbs are Kehin,  600 carbs are Mikuni.
Just be aware clutch plates are completely different to the 600, but EBC do a set code CK2371.
Carb inlet rubbers and down pipes for the 600 fit.
