Date: 10-05-26  Time: 04:38 am
Author Topic: Mk2 clocks on MK1 fzs600?  (Read 5897 times)
StreetFzr
« on: 23 September 2021, 11:38:17 pm »
so is it possible to fit mk2 clocks to the MK16, fzs 600? Or is it more chew than it’s worth?
b1k3rdude
Re: Mk2 clocks on MK1 fzs600?
« Reply #1 on: 24 September 2021, 09:35:46 am »
Someone will correct me but I believe the answer is yes, and that it should be a straight swap.
Gnasher
« Reply #2 on: 24 September 2021, 09:42:28 am »
You will need to change the connector plug, they're are different.
BBROWN1664
« Reply #3 on: 24 September 2021, 11:20:36 am »
Assuming you mean the 2002/3 FZS600 clocks on an 98/99 FZS600 then yes, as Gnasher says, they will fit (and work) with a change to teh connector plug.
If you mean FZ6 clocks on an FZS600 - no they wont work or fit.
Gnasher
« Reply #4 on: 24 September 2021, 11:41:58 am »
 :thumbup
StreetFzr
« Reply #5 on: 24 September 2021, 11:15:34 pm »
Thanks lads, I did mean the later fzs600 clocks on the earlier fzs600!
Much appreciated!!!  8)
