Date: 03-05-26  Time: 05:07 am
Author Topic: Ticking front brake  (Read 3536 times)
babemagnet
Ticking front brake
« on: 22 August 2021, 01:03:29 pm »
I've done a forum search but can't find anything similar so here goes........
I have just done full service on front brakes . New EBC discs, new EBC organic discs, new seals throughout, new fluid and new bleed screws. The only things that aren't new are the calipers. All was assembled with a touch of red rubber grease.
Problem I have is that when I apply the brake I get a fast ticking sound which remains throughout braking and slowly goes away after release. The ticking is faster than once every wheel rotation. I can only think this is some form of interaction between the edges of the pads and the edges of the holes in the discs although I have never had this noise when just replacing pads. I have changed pads from left to right but the ticking remains.
Has anyone else had this?
Will it disappear when everything settles down and wears in?
old son
Re: Ticking front brake
« Reply #1 on: 22 August 2021, 09:47:18 pm »
If it was me I’d give EBC technical a ring and talk it through with them. If the noise wasn’t there before the brake upgrade then it must be the upgrade that’s caused it.
I’ve had a ringing sound when the brakes are applied after fitting new wavy discs. It drove me mad so I put OEM back on and no noise!!
babemagnet
« Reply #2 on: 23 August 2021, 09:00:24 am »
Thanks for the EBC Technical suggestion, I hadn't thought of that.
I have just moved from EBC wavy to EBC non-wavy and sintered to organic due to heavy scoring and mot failure on the wavy-sintered combo. The old discs only lasted 15 thou miles before needing replacement for some reason.
b1k3rdude
« Reply #3 on: 23 August 2021, 09:16:33 am »
Just keep an eye out on ebay for used genuine disc with low mileage (as in, close to as-new thickness of 5mm), you will get way more mileage from these than EBC and other 3rd party rotors.
- https://www.ebay.co.uk/itm/303896281074 - 4.83mm, £90
Then hunt around for SBS pads or genuine Yam pads. EBC products have a short life span so it a false economy to buy them, thier pads eat rotors and by you own admission thier rotors dont last that long either.
