Date: 10-04-26  Time: 03:16 am
Author Topic: Yamaha fazer fzs 600 2003 model  (Read 5835 times)
neilr
« on: 26 July 2021, 10:56:48 am »
Hi
Tall order i think but I'm looking for a ignition switch for my 2003 Fazer(old on is shot!) I'm starting to believe these are reared then hens teeth. the wiring configuration for the 2003 has 7 wires but the earlier models only have 6 the only difference i can see is a feed to the alarm unit which the earlier fazers were not fitted with.
Can some one with more knowledge tell me if it is possible to fit a earlier switch or where i can aquire a 2003 model switch.
many thanks in advance for your help :'(
Gnasher
Re: Yamaha fazer fzs 600 2003 model
« Reply #1 on: 26 July 2021, 11:11:42 am »
There're 2 models of FZS600 Pre and post 2000, both main switches are the same 6 wires.  No FZS came fitted with an alarm as standard, all will have been retrofitted.   If yours has 7 it's been put there to supply a either live or switched live feed to something, possibly heated grips or sat nav, who knows people do strange things ;)
neilr
« Reply #2 on: 26 July 2021, 12:09:29 pm »
Hi
so the switch i have has 5 wires in one block and 2 wires in the second block. They look factory fitted not aftermarket or fitted by someone else. So do you think a post 2000 or a pre 2000 would still work? ill see if i can upload a picture.
neilr
« Reply #3 on: 26 July 2021, 12:48:21 pm »
Hi I’ve attached a picture of the wires on my old ignition switch and the Haynes manual shows alarms fitted to 98/99 and 00/01 models. I’m very confused now?
neilr
« Reply #4 on: 26 July 2021, 12:53:19 pm »
Just uploaded a picture from my Haynes manual, where do I go from here?
Gnasher
« Reply #5 on: 26 July 2021, 12:55:58 pm »
Here's your options the first contains how the blocks are wired, 6 wires.
https://yambits.co.uk/fzs600-fazer-ignition-switch-p-56183.html £49.99 the colours are a bit off but that's their drawing and the discription controdics itslef by stating 98 - 03 and 98 - 01 but there're all the same.
Or you can go YAM OE at £348.65 :'(
https://www.fowlersparts.co.uk/parts/4181631/fzs600-fazer-5rt4-2003-070-b/electrical-1
This is the wiring diagram for 03 FZS No 3 is the main or ignition switch, as you can clearly see 6 wires and to the left inside the dotted line the 2 connectors with wire colours.   Somebody has added an extra wire.
Gnasher
« Reply #6 on: 26 July 2021, 01:06:22 pm »
Ignore it they're often wrong, I've never seen a factory fitted alarm on a UK FZS600.  Also look at the Haynes drawing top left ignition (main) switch there's 6 wires only from the plug.   At the end of the day it's just a plug and the wire will go nowhere ;)
« Reply #7 on: 26 July 2021, 01:08:48 pm »
The 2001, 2002 Fzs1000 with the light switch on the right handlebar has the same ignition switch
neilr
« Reply #8 on: 26 July 2021, 01:18:52 pm »
Wow!
Thanks everyone thought Haynes was messing with my brain!
Gnasher
« Reply #9 on: 26 July 2021, 01:29:10 pm »
What the blue/black is doing in with the blue/red I've no idea.  It's been a while since I've work on an ignition switch on an FZS600, I can't remember seeing 7 wires, but possible.  How many wires in the female plug it plugs into?
neilr
« Reply #10 on: 26 July 2021, 03:05:16 pm »
Just added a couple of photos of the loom connections
« Reply #11 on: 26 July 2021, 04:23:12 pm »
Wow!
The Foxeye ignition switch has 7 wires and the Boxeye has 6, there was no alarm fitted to the 600 just connectors to allow the alarm to be plugged in.
If you look under the seat there are 3 white connectors with 2 loop plugs this is what the Haynes  manual refers to and the Yamaha service manual also refers to them.
Gnasher
« Reply #12 on: 26 July 2021, 04:41:32 pm »
Of course, forgot about the foxeye, I was transfixed on the boxeye  :rollin good spot unfazed:thumbup
« Reply #13 on: 26 July 2021, 07:21:39 pm »
Thought so  :D
neilr
« Reply #14 on: 09 August 2021, 03:02:58 pm »
Thought so  :D
Hi me again,
Have tried using one of these earlier model ignition switch but am having a real issue pairing up the correct wires. Can someone who's done this before please give me some insight as to what wire go where. I'm loosing what little hair i have trying to figure this out.
Ignition Switch Yamaha FZS 600 Fazer 1998-2001
