Date: 01-05-26  Time: 23:59 pm
Author Topic: FZS600 Rear Brake upgrade.  (Read 3960 times)
VinceFZS600
« on: 09 July 2021, 10:41:03 am »
Hi,
I’m looking for info on upgrading the rear brake for my ‘98 FZS600.
I’ve seen people on forums mention the fzs1000 rear brake but nobody fully answers:
Do I need the fzs1000 rear  reservoir  & what year one do I need?
Do I need a thicker disc or any supporting mods?
Anyone who can help is greatly appreciatedz.
Many thanks, Vince.
the cueball
Re: FZS600 Rear Brake upgrade.
« Reply #1 on: 09 July 2021, 11:56:23 am »
You need to cut out a bit of caliper hanger for it to physically fit - I used a Dremel style tool and just ground away, it's pretty easy, don't go in with a sledgehammer attitude...
I have a couple of thin spacers at the bolts to line up properly... this may or may not be 100% required.
Pads have to match the caliper.
Nothing else needs changed.
Think the year is early 2000's... the blue dot one, on a few different bikes as well if you don't fancy the "thou premium"
VinceFZS600
« Reply #2 on: 11 July 2021, 03:04:29 am »
Hi & thanks for the input!
So, fzs1000 rear calliper ‘blue dot’ to match to match the front, fzs1000 disc & pads, make spacers & dremmel mount to make the calliper fit.
Will give this a bash & see what happens!
Anyone on here who has a good condition one laying around please feel free to message me with a price.
Many thanks again, Vince.
the cueball
« Reply #3 on: 11 July 2021, 07:01:49 am »
Yeah, blue dot to match the front ones.
You don’t need a new disc… that stays the same as you’re still using the 600 wheel….
Of course you can get a new one for the upgrade… but make sure it’s a 600 one, not a Thou.
Only the pads need changed to match the caliper.
bwizz
« Reply #4 on: 27 August 2021, 08:23:02 pm »
Its an easy mod that works well but thou calipers are pricey. I use a Thunderace torque arm !
