Date: 01-05-26  Time: 13:15 pm
Author Topic: FZ1S vs FZ1 SA  (Read 3375 times)
Jrebera
FZ1S vs FZ1 SA
« on: 25 May 2021, 01:28:17 pm »
Can anyone help - what's the difference between an FZ1S and an FZ1SA? I assume the latter has ABS?
If that is correct, can anyone advise? I want to change Rotor Assembly for the stator - apparently the magnets can come loose from the stock version and wreck your engine. Every assembly housing I can find is for the FZ1SA - will that fit my FZ1S?
Please only answer if you know the answer rather than having a guess - cheers buds.
Gnasher
Re: FZ1S vs FZ1 SA
« Reply #1 on: 25 May 2021, 02:26:25 pm »
What year is the bike?
Bracechenko v2
Re: FZ1S vs FZ1 SA
« Reply #2 on: 25 May 2021, 03:10:47 pm »
Hi Jrebera,
More than a guess but still worth you making a call/further enquiry but I can say that the FZ1SA vs the FZ1S difference is the ABS....I can't 100% say that it's the only difference but I've always thought it was (I have a 2007 FZ1 SA).
https://www.rexs-speedshop.com/product/flywheel-rotor-yamaha-yzf-r1-fz1-1000-fzs1-fz8-800-2004-2015/
I too am looking at a replacement stator for the same reason you've highlighted....preventative cure and the link above is a company who makes a replacement part (non-OEM). The models it supports just specify FZ1 & Year and doesn't mention the S/SA variants so I assume that the parts are the same. Might be worth calling them to check though.
Thanks
Mike
b1k3rdude
Re: FZ1S vs FZ1 SA
« Reply #3 on: 25 May 2021, 04:27:29 pm »
Stainy
Re: FZ1S vs FZ1 SA
« Reply #4 on: 26 May 2021, 09:28:50 am »
Mine is an SA (ABS is the only difference as far as I'm concerned) and it clearly says 5VY on the side of the engine - as it's an engine part, you could just check for that?
Re: FZ1S vs FZ1 SA
« Reply #5 on: 26 May 2021, 11:57:42 am »
As previously stated the ABS is the main difference between the S and the SA.
There are a few other small differences especially the location of Rectfier/Regulator, but the problematic rotors are the same across all FZ1 models.
They changed the stator also around the same time, but  that may have been to match the different rotor.
