Date: 02-05-26  Time: 20:33 pm
Author Topic: White power shock help/user manual anyone?  (Read 3281 times)
Yas1
« on: 12 May 2021, 11:39:57 am »
Hi All, I just bought an FZS1000 which has a white power shock fitted. I can see there are 3 adjusters which I'm guessing are low and high rate compression, at the top, and rebound at the bottom, but I was hoping someone might have a user manual to clarify things for me please? I can't see any markings on the shock to indicate what model it is or which adjuster is which.
Any help appreciated!
Thanks in advance,
Karl
Re: White power shock help/user manual anyone?
« Reply #1 on: 12 May 2021, 01:01:33 pm »
WP are owned by KTM. Maybe one of their dealerships could help you out with info.
« Reply #2 on: 12 May 2021, 02:37:58 pm »
Generally Rebound is at the top and compression is at the bottom, that said some shock applications/manufactures fit the shock upside down.  Basic shocks have no damping adjustment just pring preload, next comes those that have either just compression or compression and rebound and redound, lastly H/L compression damping and remote preload.  It is also possible to get remote preload on some manufactures whole range and if you've got H/L damping it's usually for both compression & rebound.
Some WP shocks use a black dial/ring that you turn at the bottom blow the spring mount.
Look herehttps://www.wp-suspension.com/en-us/manuals/
Yas1
« Reply #3 on: 12 May 2021, 03:17:04 pm »
Thanks Guys, unfortunately I can't see any model information so I can't use the WP website.
The shock has 3 adjusters, 2 top and 1 bottom which I'm assuming will be low and high rate compression (top) and rebound at the bottom. I'd like to know the recommended base settings for the shock so I can work from there. I think my next option is to call a WP specialist. I fitted a second hand Ohlins to an xr400 and had fantastic support from one of their dealers
Timbo
« Reply #4 on: 13 May 2021, 08:32:29 am »
Your start point will be in the middle of the range. Thereafter test ride and adjust one at a time. Lots of info on the web, its quite easy to setup yourself
