Date: 12-05-26  Time: 04:46 am
Author Topic: Exup valve  (Read 3240 times)
fatbloke62
Exup valve
« on: 18 March 2021, 03:35:42 pm »
Hi all , a bit of advice is required,  i stripped down the exup valve this afternoon  to give it it's  annual good hiding with the copper grease, one issue i have is with the bush in the valve housing its solid even warm and a gentle tap will not shift it ,i don't want to hit it to hard and damage the housing as the valve is free  when assembled ,can leave it or should the bush be free to spin also, ta
b1k3rdude
Re: Exup valve
« Reply #1 on: 18 March 2021, 04:14:31 pm »
One issue i have is with the bush in the valve housing its solid even warm and a gentle tap will not shift it.
If its the phosphor-bronze bush thats in the outer cover, just leave it where it is. The main thing you need to check is concentricity/run-out of the exup valve, as long as the valve itself can freely rotate by hand with said cover on and the 3x allen bolts installed your good to go.
Gaz66
Re: Exup valve
« Reply #2 on: 18 March 2021, 07:49:47 pm »
fatbloke62
Re: Exup valve
« Reply #3 on: 19 March 2021, 08:18:03 pm »
Thanks for the replies gents
pilninggas
Re: Exup valve
« Reply #4 on: 23 March 2021, 10:13:43 pm »
teecee90
Re: Exup valve
« Reply #5 on: 24 March 2021, 02:49:12 pm »
Gaz66
Re: Exup valve
« Reply #6 on: 01 April 2021, 08:58:05 pm »
Holy shit £44.38 a tub ... WoWeeeee that's friggin dear grease is that.
teecee90
Re: Exup valve
« Reply #7 on: 05 April 2021, 09:25:56 pm »
You can get it cheaper than that, and one tub will last for years.
