Date: 12-04-26  Time: 06:44 am
Author Topic: Ignition Switch Lubrication  (Read 2217 times)
« on: 25 February 2021, 05:28:28 am »
Seen on here many times people asking what to use as a lube for ignition switches (where you put the key to start the bike, for the less informed) and i've finally found a winner.
Firstly, don't use graphite (sludge), WD40 (attracts dirt), degreasing spray (dries out), etc, or similar as they can seem like a temporary fix but do more harm than good over the longer term as i found out myself the hard way a few years ago.
With added (dirty) rain these can eventually turn to sludge and/or dry out on contacts in the switch causing starting/running issues or just make the turning of the key feel a bit stiff.
A few months ago i bought an electrical contact cleaner from Halfords to try as my ignition key was turning a bit stiff in the switch, and it sorted it for a while but i think after some prolonged rainfall it just dried out again.
So i tried some stuff we use at work and it has turned out to be perfect for the job.
It's still a contact cleaner so it will clean all the shite out of your switch, but it leaves a very fine lubrication as well and you can feel that everything inside moves much more freely when inserting the key.
I've deliberately waited a few months to see if it would dry out like the other one but it's still exactly the same so i can safely say it's got the thumbs up from me to use.  :thumbup
https://www.amazon.co.uk/Servisol-701-100UK-Super-10/dp/B000KEB6WW/ref=sr_1_1?adgrpid=52930236413&dchild=1&hvadid=259123271461&hvdev=c&hvlocphy=9045963&hvnetw=g&hvqmt=e&hvrand=14600591261769559742&hvtargid=kwd-329849991724&hydadcr=18510_1793628&keywords=servisol+super+10&qid=1614229382&sr=8-1&tag=googhydr-21
Re: Ignition Switch Lubrication
« Reply #1 on: 25 February 2021, 09:04:26 am »
Good shout.
CPC is cheaper but you will need to spend £20 for free delivery.https://cpc.farnell.com/servisol/100001300-200ml/super-10-200ml-switch-contact/dp/SASERVISOL?mckv=s7amMFuxK_dc|pcrid|491022676308|kword||match||plid||slid||product|SASERVISOL|pgrid|47398149059|ptaid|pla-902692058600|&CMP=KNC-GUK-CPC-SHOPPING&s_kwcid=AL!5616!3!491022676308!!!network}!902692058600!&gclid=EAIaIQobChMIgYLD_tWE7wIVt4BQBh1mdA-DEAQYASABEgIILPD_BwE
« Reply #2 on: 25 February 2021, 06:53:01 pm »
I tried having a quick look around for a bargain but thought the Amazon link might be suitable for more people if they were interested.
« Reply #3 on: 25 February 2021, 07:45:38 pm »
Nobody can get it as cheap as you  ;)
