Date: 18-04-26  Time: 13:18 pm
Author Topic: clutch lever span adjusters?  (Read 5787 times)
butthead
« on: 11 January 2021, 09:40:12 am »
hi i ve done a quick search to see if this topic has been covered before , couldn't see a match so forgive me if its been covered before ?
i have a cable operated clutch with the original levers, i struggle with winter gloves to grab the clutch lever in particular so some span adjusters would be useful.  however with cable operated clutch the lever length is likely to be important to gain the leverage to operate the clutch properly?
its almost universal that span adjusters are for hydraulic clutches and are invariably shorter than OEM .
has anyone used shorter span adjusters and found they are either a problem or perhaps not ?
can anyone offer advice to the best span adjuster levers to resolve my issue ? are there any full length adjustable levers you know of ?
just to confirm  its a 2001 fzs600.
TIA
Re: clutch lever span adjusters?
« Reply #1 on: 11 January 2021, 10:03:12 am »
Genuine question, why is it a struggle to operate the glove with winter gloves?
As you have mentioned, i doubt you'd get the amount of cable pull needed to effectively disengage the clutch if it was altered in any way, and i would imagine it would feel quite clumsy too with winter gloves on with the lack of space between the lever and grip.
butthead
« Reply #2 on: 11 January 2021, 11:53:53 am »
Hi Darsi, yep fair question and the answer is im a small bloke and my hands are smaller than average, my finger length therefore is shorter giving me this  reach issue not terrible but made worse by thicker gloves worn in winter.  so some dexterity is lost with thicker gloves and as the material is bulkier in the palm and fingers exacerbates the reach ( span issue )
my triumph bonneville has normal length levers is also cable clutch but has span adjusters both levers.  so i wondered if you can get OEM length levers for the fazer but with span adjustment or if anyone has tried other lever options that could resolve the issue.
FILZ6
« Reply #3 on: 11 January 2021, 12:28:53 pm »
Hello butthead.
On my fzs600 foxeye 2002, I had Pazzo levers fitted, which had span adjusters on both brake and clutch levers, I never encountered any problems with clutch actuation. I also had these levers fitted to my fzs1000 with no problems.
I removed these levers when I sold the bike, so they should be in my garage somewhere. If you are interested I could dig them out and send details and photos of them.
butthead
« Reply #4 on: 11 January 2021, 12:55:17 pm »
Hello butthead.
have pm'd you though my model precedes yours 2001 box eye
BBROWN1664
« Reply #5 on: 11 January 2021, 01:49:18 pm »
98-2003 are all identical mechanically so they will fit.
FILZ6
« Reply #6 on: 11 January 2021, 02:00:33 pm »
BBrown1664 Thank you for that info.
Disorderlypunk
« Reply #7 on: 11 January 2021, 02:05:07 pm »
bar muffs can be a great alternative as i was having a similar problem years ago while riding about 30miles each way for work throughout winter
i ended up only wearing 'magic gloves' under the bar muffs and was nice and warm (we need to invent footrest muffs as my feet were still frozen)
FILZ6
« Reply #8 on: 11 January 2021, 03:35:01 pm »
butthead.
 Here are some photos of my span adjustable Pazzo levers.
There are a lot of bikes with cable operated clutches that have span adjustable levers fitted as standard, so you should have no worries changing yours from unadjustable ones.
Sorry they are upside down, they were the other way up on my computer screen, doh!
Disorderlypunk
« Reply #9 on: 11 January 2021, 05:19:03 pm »
best 8+ inches ive seen since my last post on pornhub.
« Reply #10 on: 11 January 2021, 06:46:14 pm »
Still can't imagine you getting enough pull to disengage the clutch?
Obviously you can if you had them fitted, but to look at I would've thought the lever would hit the grip too early!
Gnasher
« Reply #11 on: 11 January 2021, 08:19:07 pm »
They work fine, you only need around 10mm of pull on a correctly adjusted clutch.
Jules-C
Disorderlypunk
« Reply #13 on: 12 January 2021, 09:45:13 am »
https://www.ebay.co.uk/itm/Clutch-Brake-Levers-Fit-Yamaha-FZS600-FAZER-1998-2003-CNC-Short-Long-10-Colors-/282270785115?_trksid=p2349624.m46890.l49292
CNC levers on eBay have span adjusters on both brake and clutch.
i bet my left testicle they are not cnc machined, they will be cast in a cheap alloy
Disorderlypunk
« Reply #14 on: 12 January 2021, 09:55:44 am »
in fact watch this, if you look closely they look identicle to those cheap ebay ones, i wouldnt touch them with a barge pole
Gnasher
« Reply #15 on: 12 January 2021, 10:02:11 am »
The price is the big give away, cheap Chinese crap.
NJD
« Reply #16 on: 13 January 2021, 12:40:35 am »
Bit late to the party.
I swapped out the O.E.M clutch lever not long after I got the bike for a "Synto Evo" adjustable lever that I got from eBay (second hand) and personally I find it an improvement. Adjustment position is closer to the bar by a fraction (5 / 6 -- 6 being furthest out / O.E.M) but that's all I needed. I've never had any problems with clutch adjustment.
Try and stay away from the generic poorly made eBay stuff, but at the same time it can be a great platform for getting parts at a bargain price. HTH.
edit: or PM FILZ6 above for a price on his set. Think you'd be safe in the knowledge that another biker wouldn't sell you tat for such an important part, and saves taking a chance online. :thumbup
