Date: 08-05-26  Time: 23:22 pm
Author Topic: Brake pad retaining pins  (Read 4646 times)
Kenbob
« on: 19 November 2020, 04:38:58 pm »
hi all.
Quick question.
Should I coat new brake pad retaining pins with a thin film of worth’s brake paste or just the ends that are in the Caliper.
teecee90
Re: Brake pad retaining pins
« Reply #1 on: 19 November 2020, 08:00:06 pm »
The only grease I use is a little red rubber grease when cleaning/replacing brake pistons/seals. No need for any grease or lubricants anywhere else.
coffee
« Reply #2 on: 20 November 2020, 09:01:05 pm »
Everyone to his own I've always put a bit on the pins just because the pads move along them,it might not do anything but I've done it for years now,it's probably a habit. ;)
b1k3rdude
« Reply #3 on: 20 November 2020, 09:18:35 pm »
same here, a thin film of copper grease on the pins.
robbo
« Reply #4 on: 20 November 2020, 10:09:45 pm »
Yep, me too. Use the same high melting point copper grease that I use on the exup valve. Some on the back of the pads as well.
teecee90
« Reply #5 on: 20 November 2020, 10:56:10 pm »
I used to do the same but stopped using copper grease 2-3 years ago and it is so much easier to keep the callipers and pads clean and working well. I found that copper grease just attracts all sorts of grit and crap turning into grinding paste and for no real benefit. From what I remember, there is nothing in the service manual about using grease anywhere on the pads or pins.
dangerousdave
« Reply #6 on: 21 November 2020, 12:19:18 am »
A rub with copper grease stops them corroding and makes them much easier to remove next time.
teecee90
« Reply #7 on: 21 November 2020, 10:43:28 am »
I’ve got titanium pins in the front and OEM pins in the rear. No rust or corrosion on either. Regular cleaning and maintenance is the key.
Kenbob
« Reply #8 on: 21 November 2020, 07:49:26 pm »
Thanks for the replies.
Blue spot calipers are great calipers and I have only ever had one seize up on me despite my lack of brake maintenance and riding all year round.
 I recently saw a delboy video where he shows caliper maintenance so I thought before this winter really sets in with the gritters out and about I would treat said calipers to new pad pins all round and a good wash.
Feeling guilty about my Caliper abuse.
teecee90
« Reply #9 on: 21 November 2020, 08:28:55 pm »
Delboy’s videos are good for entertainment value, but that’s about all....
kralik
« Reply #10 on: 26 November 2020, 04:57:28 am »
Where did you get the titanium pins from please?
coffee
« Reply #11 on: 26 November 2020, 10:39:03 am »
+that one  :lol
teecee90
kralik
