Date: 08-05-26  Time: 00:46 am
Author Topic: Nervous Speedometer  (Read 2065 times)
ArchDruid
Nervous Speedometer
« on: 10 November 2020, 05:06:38 pm »
Before I start taking things apart, I though I'd put it out there to see if someone could point me quickly in the right direction.
My speedo reading has always had a stable reading regardless of the speed. But now I've noticed the needle is getting a bit 'jumpy'. It gets worse the faster I go.
Starts getting nervous at about 50.   At 70 it bounces around between 65 & 75. And at about 120, its bouncing around between 100 & 140  :lol).
Anyone had a similar issue ?
coffee
Re: Nervous Speedometer
« Reply #1 on: 10 November 2020, 06:17:50 pm »
Tell you what,I think I'd be bouncing about at 120 !!? :lol  seriously,some of these speedos have a weird system inside and I don't think you're going to rectify it without foccing it up I'd try a breakers'.
coffee
« Reply #2 on: 10 November 2020, 06:29:35 pm »
Just thinking,it wouldn't be anything to do with the cable would it? maybe needing WD40 down it,that's if it's a cable I don't know anything about gen1's......don't know a fat lot about gen 2's either......don't know a lot about anything really....dooby doo doo doo daa  :crazy
ArchDruid
« Reply #3 on: 10 November 2020, 10:42:20 pm »
OK then, I think I'm just going to have to bite the bullet & get stuck in. Checking wiring connections is the easy bit. Maybe I'm lucky and its just dirty connections causing distortion at higher frequencies....
Really don't want to get down underneath to change the sensor if I don't have to. Its in an ungodly place at the back of the crankcase, close to the swingarm pivot ... :rolleyes
coffee
« Reply #4 on: 11 November 2020, 01:01:37 pm »
Obviously not as straightforward as I thought ! don't envy you that one. Have you tried asking your local Yamaha dealer for any advise ?
