Date: 07-05-26  Time: 03:14 am
Author Topic: Fuel pump remains on with ignition off  (Read 2740 times)
Bikebud
« on: 23 September 2020, 05:31:42 pm »
Hi all,
I had my bike washed a few days ago, and it seems that water got through to some loose wiring (the bike has alot of after market add on and shaddy wiring). When I switched the ignition key, the engine started on its own, indicators blinked randomly, and Check Engine and ABS lights came on.
I left it to dry out in the sun, and engine start, engine check light, and indicators went away. But the ABS light remains on (i think the ABS has stopped working) and even when I take the ignition key off, the fuel pump keeps buzzing, until it drains the battery.
But otherwise the bike starts and seems to run fine.
Any ideas what causing the fuel pump to stay on? I plan to lift the tank start disconnecting things until I find the culprit, but not sure where to start.
