Date: 06-05-26  Time: 19:49 pm
Author Topic: Fazer gen 1 float needle seat o ring  (Read 3073 times)
Johnrambo20
« on: 09 September 2020, 10:59:56 am »
 is there anywhere in the uk or Europe where I can just buy the float needle seat o ring want to change them without buying a full kit if any body has brought them plz advise me where I can buy them thanks
b1k3rdude
Re: Fazer gen 1 float needle seat o ring
« Reply #1 on: 09 September 2020, 01:34:55 pm »
Are you refering tp part 7. from the following list..?
https://www.fowlersparts.co.uk/parts/4189107/fzs1000-1c28-2005-050-b/carburetor
Have you had a look online for an oring kit -
https://www.amazon.co.uk/Rubber-O-Rings/s?k=Rubber+O+Rings
Bear in mind you will need to check the rubber used is impervious to petrol.
FILZ6
« Reply #2 on: 09 September 2020, 03:59:01 pm »
Measure the inside diameter, and the cross section, then look on e bay for that size “o” ring. You may have to buy 10, that’s more than you need but far cheaper than carb kits. Look out for ethanol resistant material.
I have done it this way on a cbr600 and a bandit 1200 pilot jets in the past.
Hope this helps.
Johnrambo20
« Reply #3 on: 09 September 2020, 04:42:39 pm »
In the exploded diagram it’s part of pic 18 I’ve got o rings but need the o ring that’s suitable for petrol not water
Trebus
« Reply #4 on: 09 September 2020, 07:49:07 pm »
Johnrambo20
« Reply #5 on: 09 September 2020, 08:06:13 pm »
So quick update after doing some research which o rings can be use with petrol found them on eBay same as the ones that are listed on pats ivans kit  Installation Site
The one on his site r in USA and they won’t ship to uk but I’ve matched them on eBay if any body needs them they r 1.5mm cross section x 7.5mm inner diameter 10.5 mm outer diameter pack 100 £6.41
https://www.ebay.co.uk/itm/133276294777
ArchDruid
« Reply #6 on: 09 September 2020, 11:04:07 pm »
try   nrp-carbs.co.uk    I've bought bits & pieces there before, can't remember what tho ...  Maybe not always listed on the website, so best to pick up the phone and chat to them. Always been helpful with me that way.
