Date: 06-05-26  Time: 11:05 am
Author Topic: 2007 FZ1 will no start  (Read 3271 times)
Budthewiser
« on: 23 August 2020, 12:19:54 pm »
The rebuild on the FZ1 is nearly finished, i tried to start it yestersay but it wown't start. The pump primes but the nothing, not even trying to turn over. When i try and start it, the engine light comes on, Any ideas. Loose wire fuses side stand?
Dudeofrude
Re: 2007 FZ1 will no start
« Reply #1 on: 23 August 2020, 01:08:20 pm »
Have you looked at the diagnostic menu to see if its shows any error codes? Thats usually a good indicator of any problems
Also check the obvious things, kill switch, battery or for instance I thought mine was knackered the other week when it was doing the same as yours, but turned out I'd left it in gear when I turned it off which then stops the starter kicking in 😳😳 was both embarrassed and relieved at the same time haha
Gnasher
« Reply #2 on: 23 August 2020, 01:36:13 pm »
 :agree ;)
Budthewiser
« Reply #3 on: 23 August 2020, 10:23:53 pm »
Got it going, loose wire under the seat, I just disconnected and reconnected  everything and  ...BOOOM ...shes firing on all 4. Still waiting on handle bars, front left indicator and crash bobbins and shes finished. Thanks lads.
b1k3rdude
« Reply #4 on: 24 August 2020, 09:08:38 am »
Ah that sound like corrosion on one or more of the pins then, if you can it would be a good idea to get inand clean them if you can, otherwise liberly spray WD40 into both parts of the connector and unplug-plug a few times. Got a pic of the connector btw, Im curious to see which one it is...
Budthewiser
« Reply #5 on: 29 August 2020, 01:26:15 pm »
I'll have a look but it wownt start now, j think it's the fuel  pump relay. The connectors looked ok on the startef relay.
Budthewiser
« Reply #6 on: 31 August 2020, 10:32:30 am »
