Date: 21-10-25  Time: 04:51 am
Author Topic: Arrrrrrr bike is dead,help  (Read 1521 times)
dilboy
« on: 06 August 2020, 05:17:32 pm »
Hello all
Turn key nothing
Battery fully charged,all fuses ok,all connectors connected
Anything else I can check ?
Re: Arrrrrrr bike is dead,help
« Reply #1 on: 06 August 2020, 05:21:19 pm »
Starter rely, would be a good place to start.
Half my post got deleted Arrrrr  :rolleyes
If it's clicking, check the side stand and clutch switches, if no joy with any of that come back.
BBrown has now mentioned some of the above  ;)
« Reply #2 on: 06 August 2020, 05:39:49 pm »
No lights at all or not turning over?
If no lights at all then it has to be the battery (have you tested it with a meter to check 12v?) or the main fuse.
If you have the neutral light, press the starter button and the dash lights up like a Christmas tree, then check the kill switch is on. If the dash doesnt light up like its Christmas, pull in the clutch lever and put the side stand up before hitting th estart button again.
dilboy
« Reply #3 on: 06 August 2020, 06:44:26 pm »
No click,or dash lightning  up
Will check starter motor
« Reply #4 on: 06 August 2020, 06:49:27 pm »
It's the starter rely not the motor you need to check.  What have you done to the bike since you last used it, or was it fine last it was used?
dilboy
« Reply #5 on: 06 August 2020, 08:09:29 pm »
It was ok
But sluggish,so removed carbs,cleaned and put back in
« Reply #6 on: 06 August 2020, 09:20:19 pm »
You say the battery is fully charged, have you checked the voltage?
If your getting no lights, it wont be the starter motor or solenoid normally. Start by checking the basics. Battery was removed to remove the carbs. Did you put it back in the right way round? IS it really charged? Are the connections on properly? Have you dislodged the fuse?
dilboy
« Reply #7 on: 09 August 2020, 02:35:34 pm »
Battery ok
Power going into starter solenoid but now power going out,so ordering new one,hope that's it
« Reply #8 on: 09 August 2020, 05:13:40 pm »
have you checked the starter button actually works before plumping for the relay?
« Reply #9 on: 09 August 2020, 05:47:02 pm »
ive got a wierd feeling no power is going up to the front at all - there will always be power going to the starter relay as one post is connected to the battery - i would be looking at all the connectors first and giving them a clean
dilboy
« Reply #10 on: 15 August 2020, 09:12:52 pm »
changed the starter solenoid and there is life in the old girl
cheers all for the advice
 :lol :lol :lol :lol :lol
