Date: 05-05-26  Time: 21:37 pm
Author Topic: 03 R1 fork triples vs. Gen2 triples  (Read 5689 times)
killerwhaleTRX
« on: 29 July 2020, 09:31:00 am »
Hi guys and gals!
I have the fork swap document here so i have looked into offsets and rake and all. BUT.....
Has anyone looked into differences in the triple trees?? I´m keen on just use the legs but what does that mean in the lower departement?
I know my TRX used spacers for wheel mount...
Cheers
Mattias
ArchDruid
Re: 03 R1 fork triples vs. Gen2 triples
« Reply #1 on: 29 July 2020, 04:08:45 pm »
Not sure what you're trying to do here.... Gen2 ??
I've done a R1 fork conversion on a Gen1 with 5PW bottom yoke + 2D1 (FZ1) top yoke.
killerwhaleTRX
« Reply #2 on: 29 July 2020, 05:20:22 pm »
Got a complete fork wich been on a TRX, but just want to use the legs and not involve a lot of stem changes and stuff. I guess its up to the width between the legs because lenght, rake and offset is just about the same.
Will go down to the shed later and measure the R1 width.
Theese fork legs are to good to sell with the Matris in ´em  :)
killerwhaleTRX
« Reply #3 on: 29 July 2020, 05:53:55 pm »
R1 2003 was 160mm inner/inner leg. 50mm top yoke, 54mm bottoms.
Can´t measure the fizzer due to a frekkin storm today :)
ArchDruid
« Reply #4 on: 30 July 2020, 11:12:12 pm »
Centre-to-centre for the forks on the early R1's is 210mm. Same for YZF750, Fazer1000, FZ1, and FZ8.
I think the TRX850 and FZR750/1000 is 200mm. Later model FZR's (with USD forks) were 210mm.
Not 100% sure on that though. Better to double check.
killerwhaleTRX
« Reply #5 on: 31 July 2020, 10:12:57 am »
Top stuff mate! So i guess that if FZ1 triples are 54/50mm ill be good just stuff the fork right in there.
Its sitting there with new rubber, new wavediscs and serviced gold spots :) Its a TRX front wheel but got the correct spacers to use the R1 triples.
Nice weather here today at last so will be doing some measurements to be sure.
Cheers
