Date: 06-05-26  Time: 17:30 pm
Author Topic: R1 fork mod Can the later forks with Radial calipers be fitted?  (Read 3356 times)
Gaz1978
Hi All, So after much deliberating with myself I am going to try using the R1 forks (4xv 5jj 98/99 type) but have seen that the later model (5vy 04-06) Look similar in design bar the radial mounted calipers.
Does anyone know if this is possible?
Cheers Gaz.
@kebab19 @pieEater
killerwhaleTRX
Re: R1 fork mod Can the later forks with Radial calipers be fitted?
« Reply #1 on: 07 July 2020, 04:49:31 pm »
Cheers Gaz.
Absolutely, i have a doc found online with all lengths, offsets and rakes for all years of R1 forks compared to the FZ1. I put a 2003 fork on my TRX way back and one should always know that you change rake and wheelbase etc when doing stuff like that.
I still have my R1 fork in the basement so contemplating putting it in the FZ1 just because i also have Matris catridge @ 1000£ in them :)
Cheers
Mattias
@kebab19 @pieEater
kebab19
« Reply #2 on: 07 July 2020, 07:28:39 pm »
From memory, 4XV forks are one of the longest sets you can get, whereas 5VY are one of the shortest?I found that even with 4XV there was a fairly noticeable front-end drop.
killerwhaleTRX
« Reply #3 on: 08 July 2020, 06:23:43 am »
Found it:
http://1.bp.blogspot.com/-GS-sydb2h1g/Trs61bA76EI/AAAAAAAALfw/qEfZD5MB55E/s1600/r1+fork+comp.png
tex
« Reply #4 on: 08 July 2020, 08:41:10 am »
If you take a look at the old 100 owners club sight there is a good guide by Mike , falcon on the r1 swop
Gaz1978
« Reply #5 on: 08 July 2020, 09:32:50 am »
Thanks for all of your help so far guys its very much appreciated 😊
ArchDruid
« Reply #6 on: 11 July 2020, 10:53:50 am »
From a yoke perspective, they are mechanically similar, except the offset. As long as the forks fit in the yokes - 54mm bottom yoke and 50mm top yoke (if I remember correctly), you should be fine.
As for the forks themselves, using 4XV / 5JJ forks, you can use the original Fazer axle, wheel & brakes.
With 5PW forks, you’ll need the 5PW front axle, but the original wheels & brakes can be used.
With later model forks, (5VY onwards) you’ll need the complete axle, wheel and brakes, and master cylinder (?). Because of radial type brakes and different size brake rotors
The various forks have different lengths, all of which are shorter than the original fazer (588mm). So its always going to be lower at the front, no matter which forks you use – just a question of how much lower.
5XV & 5JJ are about 544mm. I think they are the longest of the R1 options.
5PW & 5VY are about 520mm.
My collection of info may not all be correct, so happy if someone could confirm.
OSKARO
« Reply #7 on: 03 September 2020, 09:10:37 pm »
I'm interested to this thread.
my intentions are to swap the FZ1 (2d1) with 5vy, what change with the Axle? can I keep the wheel and the rotors and change only the bearings?
the 5mm of length difference shouldn't effect too much the FZ1, right?
Anyone could help to understand, please?
