Date: 05-05-26  Time: 06:32 am
Author Topic: Boosterplug good or bad?  (Read 1373 times)
c.swilkins
« on: 06 June 2020, 06:59:22 pm »
Hello,
newish to the group so hi all, just wondering what the general thoughts are of the booster plug as an add on? Where fitted has it been a big success of a head ache.  I have 2009 FZ1N.
Gnasher
Re: Boosterplug good or bad?
« Reply #1 on: 07 June 2020, 10:08:25 am »
It depends what you're looking for and think you're going to get by fitting one.  If you're after more BHP top end, forget it, if your want improved throttle response/rideability then yes you'll see a marked improvement, whether that's worth £125 ish is up to you.
All these things do, is get rid of the environmental/noise restrictions (holes) manufactures put into the engine maps to get through EU/world regulations. Mostly by fooling the ECU into thinking the air temperature is lower than it is for a given rev range, so the ECU puts is a bit more fuel, you can do the same with a simple resistor, that cost pennies.  Don't confuse these with a power commander, the latter is a proper engine mapping system.
If you've got an aftermarket end can/exhaust and/or you've removed the O2 sensor it wont work as it should.
