Date: 10-05-26  Time: 00:29 am
Author Topic: Width of handlebars / front indicators  (Read 2300 times)
pezos
« on: 24 May 2020, 10:45:37 am »
Hi all,
I wondered if someone with a fzs600 might be able to put a tape measure across the front indicator and handlebars for me. I am looking for a new bike and need one that will squeeze through my gate.
Thanks alot in advance
Re: Width of handlebars / front indicators
« Reply #1 on: 24 May 2020, 10:58:01 am »
Not in a position to measure right now but I used to have the same issue, on paper it was too wide but still went in at an angle and then sort of lean a little left and then right and it went in but also keep an eye on the end can. Mirrors are  wider than everything and need folding in too.
Gnasher
« Reply #2 on: 24 May 2020, 11:18:29 am »
It's not the handlebars or indicators you need worry about, as you can walk the bars through and fold the mirrors in.  It's the width of the firing and weather it's a straight run once past the gate, or whether the gate actually opens fully and back past the gate post.
I used to push mine in and out of my side gate, which was your standard gate, with a straight run and the gate fully opened behind the post.
pezos
« Reply #3 on: 24 May 2020, 11:58:40 am »
Thanks for the replies, should have said my fzs 600 went though by the skin of its teeth, and it was the indicators that I had to watch out for which is why I'm curious about the width. Most bikes seem to be wider than the fazer for some reason!
