Date: 13-05-26  Time: 02:18 am
Author Topic: gen 1 fazer notchy gear change  (Read 3154 times)
seano
« on: 20 May 2020, 05:48:57 pm »
hi my 05 is a bit "notchy " through the gears and clunks when selecting first, never slips out of gear just have to be positive foot movement any ideas????
old son
Re: gen 1 fazer notchy gear change
« Reply #1 on: 20 May 2020, 10:18:03 pm »
Probably needs the chain adjusting correctly. Check the manual. It would also be a good idea to lubricate the linkages.
seano
« Reply #2 on: 21 May 2020, 06:50:06 am »
thanks but i have done that
bludclot
« Reply #3 on: 21 May 2020, 07:23:51 am »
The gen 1 is seems sensitive to clutch its cable, I think it's because it goes through 4 angles between lever and housing. Is yours a genuine cable? If so it will need to be adjusted 'just so' for a smooth change and an easy to find neutral. I and others on this forum have tried after market cables and have promptly changed them for genuine.
celticbiker
« Reply #4 on: 21 May 2020, 08:24:49 pm »
Make sure your shift lever pivot is clean and lubed too.
My fz8 gets notchy when it's ready for a lube.
seano
« Reply #5 on: 22 May 2020, 02:56:04 am »
  not sure if its gen but its in good condition and adjusted
seano
« Reply #6 on: 22 May 2020, 02:57:33 am »
thanks il give that a go
