Date: 13-05-26  Time: 01:17 am
Author Topic: Fazer 1000 gen 1 2005 wheels  (Read 2494 times)
Ripsnortingvtwin
« on: 19 May 2020, 04:43:16 pm »
guys
i have seen a few 1000 with 5 spoke wheels ( now i have the i wants  :) :) ) any done this ? and can tell me what needed to convert i think its r1/r6 wheels
any if you have done this please can you tell me whats needed
thanksmike
Tmation
Re: Fazer 1000 gen 1 2005 wheels
« Reply #1 on: 19 May 2020, 07:25:15 pm »
I think the Gen 2 wheels fit with a little bit of fettling.
I did look at this about 10 years ago but never bothered, so can't confirm one way or the other.
I also seem to remember Devilsyam (RIP) telling me that to fit the R1 rear wheel you need to have a disc made up to fit.
Have you been through the Gen 1 FAQ sticky on this forum?
Hopefully someone will come along soon and give you the proper information.
NorthWestern
« Reply #2 on: 19 May 2020, 08:29:32 pm »
Early R1 rear isn't a straight swap due to the disk offser and radius being different. I believe the later ones just need a different disk.
I fit a 4xv one to mine but it requires work:
http://foc-u.co.uk/index.php?topic=18950.msg222278#msg222278
Red Ceri
« Reply #3 on: 20 May 2020, 02:03:52 am »
I fitted 2003 R6 wheels to my 2003 Gen1. Both wheels have the same rim size so tyre size is the same.
front wheel is a straight swap, except for the discs, as the later Yam wheels are 5 disc bolt fitting rather than 6 as on the Gen 1s.
Rear wheel takes the Gen 1 sprocket carrier and spacer so the left side of the rear wheel is OK. The Brake side needs some more thought and at least one extra wheel spacer.
I ended up using a GEN 2 ABS rear caliper and carrier that I modified with a welded plate to match the Gen1 torque arm. I needed a different rear disc (again 5 vs 6 bolt fixing) and i think i ended up with a Gen 2 rear disc as well.
Ripsnortingvtwin
« Reply #4 on: 20 May 2020, 06:33:01 pm »
thanks for this , i am going to do this over the winter as i found the old race bike wheels there off a 5sl 2005
