Date: 10-05-26  Time: 04:19 am
Author Topic: Exhaust header nuts.  (Read 2645 times)
vinnyb
Middy2000
Re: Exhaust header nuts.
« Reply #1 on: 27 April 2020, 07:30:28 am »
They are a good option as a replacement as they help to prevent corrosion from water ingress.
My reservation is the quality of the ones you propose.  They are from China, the steel will be of dubious quality and soft as hell.  You'll round these putting them on let alone taking them off in a few years.
By all means go for the idea but look for some decent stainless ones.
robbo
« Reply #2 on: 27 April 2020, 08:30:04 am »
+1   What Middy2000 said. Kays Fasteners is a good firm to deal with. If the dome nuts aren't deep enough, you can either use a regular stainless nut first and then cap it off with the dome nut, or cut the length of the stud thread and just fit a good quality stainless dome nut. Personally I went with the first option.Either method is certainly a good idea to protect the stud thread. :thumbup
Disorderlypunk
« Reply #3 on: 27 April 2020, 08:59:58 am »
just use a bit of loctite 222 (purple low strength) reduces the chance of corrosion dramatically and creates a barrier against galvanic corrosion
+ being low strength wont give too much resistance when removing
a lot of boat builders use something called tefgel but its bloody expensive and i dont think has any anti loosening property's
vinnyb
« Reply #4 on: 27 April 2020, 04:18:29 pm »
 Oops! I'd already bought them. No worries if they're crap I'll buy something else but I thought for the sake of 3 quid, they were worth a look.
vinnyb
« Reply #5 on: 02 June 2020, 05:56:00 pm »
 Finally arrived today. They don't look too bad on.
