Date: 11-05-26  Time: 23:43 pm
Author Topic: Chain Case Cover  (Read 2533 times)
WayneUK
Chain Case Cover
« on: 08 April 2020, 10:21:18 am »
Hi all,
Just wanted to know the best way of removing the chain case cover to get to the front sprocket?
robbo
Re: Chain Case Cover
« Reply #1 on: 08 April 2020, 10:48:33 am »
You'll have to remove the gearchange linkage first, then the sprocket cover. One end of the linkage is left hand thread. Make a note of how much thread is used as you dismantle, so that the gear lever can be returned to its current position.
WayneUK
« Reply #2 on: 08 April 2020, 10:58:13 am »
This is the bit i wasn't sure about removing, which end is the left had thread? and what will be the best way of removing gearchange linkage?
« Reply #3 on: 08 April 2020, 11:02:27 am »
hi wayne...remove the foot rest and linkage in one piece,disconect the linkage from the gearbox end...three hex bolts hold the footrest to the frame...
WayneUK
« Reply #4 on: 08 April 2020, 11:19:26 am »
Hi red,
That sounds a good way, I'll give that a try , Thank you
