Date: 18-03-26  Time: 10:14 am
Author Topic: Centre stand return isn't  (Read 8563 times)
Re: Centre stand return isn't
« Reply #25 on: 09 April 2020, 12:42:40 am »
When you remove the springs check the movement, it should be very free, not sticky.
« Reply #26 on: 09 April 2020, 05:10:19 am »
Quote from: darrsi
Link for the springs is in my first post. Bit expensive though.
Sorry, I missed that. Yowsers, 27 quid for springs. I could get them from my last work for less than a fiver for sure, if I could get the dimensions. I guess I'll measure what I've got and take a punt.
Looking at the video,my money would be on either the stand being twisted, or something causing rubbing at the joints. I don't reckon it's the springs.
As Unfazed says, if you take one of the bolts off, unhook the spring, then replace the bolt again and see if the stand still has that jerky movement and it will answer the question.
« Reply #27 on: 09 April 2020, 10:45:20 am »
 :agree   :thumbup
Kenny Dave
« Reply #28 on: 09 April 2020, 09:20:07 pm »
OK so it's working ok. I had it off and got the dremel on everything, no paint or rust. In the hole, on the sides, on the frame, on the stand. I also noticed that it moves ok without the nuts on, so I've got them on at 20Nm now instead of 30, which I'm hoping is ok with the lock nuts and threadlock.
It doesn't seem bent, I've added pictures to the gallery:
Thank you all for your guidance, lots of good stuff on here.
« Reply #29 on: 10 April 2020, 10:06:47 am »
Quote from: Kenny Dave link=topic=26042.msg312195#msg312195 date=1586463607
It doesn't seem bent, I've added pictures to the gallery: [url=https://imgur.com/a/epPehsa
[/url]
They also suffer a crush effect when falling over, this pushes one leg in, raising the height of the bridging section the the spring attaches to.  Thus reducing the spring tension and how much it pulls the stand up, when bent and it doesn't take much they flap like yours is.  The loosening the bolts will have no effect as the stand was freely moving, over tightening does as they stick.
« Reply #30 on: 10 April 2020, 10:15:44 am »
Why have you got 4 boxes of bananas in your garage  :lol
Kenny Dave
« Reply #31 on: 10 April 2020, 02:13:52 pm »
Do you think that's not enough bananas? Are you selling any?  ;)
Kenny Dave
« Reply #32 on: 14 April 2020, 04:51:52 pm »
Just for you Fazersharp:
« Reply #33 on: 14 April 2020, 06:13:47 pm »
Are those marks on the floor your centre stand dragging  :lol
Kenny Dave
« Reply #34 on: 15 April 2020, 04:39:13 pm »
The workmate dragging with the clamp attached ;) See if you can see it in the picture, you are very Eagle eyed!
« Reply #35 on: 15 April 2020, 08:36:15 pm »
That's where my user name comes from  ;) Yes you have dragged it almost out of the shot. Hows your cat ?
Kenny Dave
« Reply #36 on: 15 April 2020, 09:16:31 pm »
blackvyper
« Reply #37 on: 12 May 2020, 07:27:11 am »
My center stand did the same thing to me last month.  I checked the spring and then sprayed it with some WD40, then I raised and lowered it a few times to work the oil in and it was just fine.  Sometime dirt and oil get into the bolts and need to be ceaned out an lubricated.
