Date: 08-05-26  Time: 14:29 pm
Author Topic: Disconnecting the alarm on my 2001  (Read 3201 times)
fordlatch41
« on: 31 March 2020, 02:51:06 pm »
has anyone managed to disconnect the alarm on a 2001 model,and got it running without,  took my alarm off today(meta, so non original Yamaha) but then I was left with 7 black wires all with a silver band on them, one of the wires comes out of the ecu, the others come out of the main harness, 3 are live with ignition on and 3 are not live. Question is what wires need connecting/ taping up to get it running again.
Gnasher
Re: Disconnecting the alarm on my 2001
« Reply #1 on: 31 March 2020, 03:00:09 pm »
You will need to rejoin the the ECU circuit where it was cut to go through the Meta, which acted as the immobiliser.  What wire they've used you've got to figure out using continuity test and elimination.
By the way Meta was Yamaha back/approved and fitted by dealers to new Yams as optional extra.
grahound
« Reply #2 on: 01 April 2020, 07:41:55 pm »
Have you still got the original alarm sockets on bike ?
If so you just need to connect the right terminals.
limax2
« Reply #3 on: 01 April 2020, 09:23:33 pm »
Don't know if this will help you. I've just had a look at my 2001 FZS600 that has never had an alarm on from new[size=78%]. [/size]
i assume you are referring to the 7 wires under the seat on the drive side.
Plug with 4 wires. A wire loop connects the two wires nearest to the plug catch. Other two wire left open circuit.
Plug with 2 wires. Both wires connected.
Plug with 3 wires (with a bit of my own red tape on). All left open circuit.
hopefully the photo will illustrate it.
fordlatch41
« Reply #4 on: 04 April 2020, 10:11:55 am »
No they are missing, so I have a real problem I guess.
fordlatch41
« Reply #5 on: 04 April 2020, 10:19:12 am »
Thanks for the photo, I now know that is what my bike should have on the loom, however they are missing from mine, so 2 pairs are joined together while 2 are not connectected,  I am left with seven bare wires and they are all black,  I'm going to have to guess where the ecu wire connects to. The manual isn't much help either it just shows a single multi plug with all black wires
Gnasher
« Reply #6 on: 04 April 2020, 10:44:46 am »
Yours would appear to be a professional fitment, the wires being all black, this is so a thief couldn't tell which wires were what like you can't.  You either do the above or you should be able to cut back/remove the wiring loom sheath back enough to see where they cut a soldered in the black wires.
If you just guess as you put it you run the risk of blowing the ignition box, what you're calling the ECU.
