Date: 11-05-26  Time: 02:34 am
Author Topic: Gear position indicator ?  (Read 3915 times)
Stormbringer
« on: 10 January 2020, 03:26:39 pm »
Anyone fitted a gear position indicator and if you have where did you tap in to the loom?
CatalinU
Re: Gear position indicator ?
« Reply #1 on: 10 January 2020, 04:12:28 pm »
I just got one from ebay. Not fitted yet as is cold in the winter
robbo
« Reply #2 on: 10 January 2020, 05:06:28 pm »
I fitted a HealTech to my Gen1. The instructions were quite straight forward, but could be different for your FZ8 though.
agricola
« Reply #3 on: 10 January 2020, 05:20:57 pm »
Yes. FZ6 S2 fazer though. Healtech Gipro. Theres a recent thread in the FZ6 pages, may shed some light on it for you
robbo
« Reply #4 on: 10 January 2020, 09:57:43 pm »
If the model for the FZ8 instructions are similar to a Gen 1, then other than +ve and -ve, you'll need to identify the crank position sensor lead, and also the speed signal wires coming from the ecu. Using a multimeter and a needle to pierce the insulation, is how I identified the correct leads. If you go for the HealTech GiPro make sure you order the model specific to your bike.
Johnnylad123
« Reply #5 on: 27 January 2020, 05:27:15 pm »
Robbo, which model of Gipro did you get, seems to be loads of them!
robbo
« Reply #6 on: 27 January 2020, 05:57:40 pm »
From memory it was the GiPro X type G2. There are some moody Healtech copies about than can cause ecu problems. If you go on the Healtech site, you should be able to input your bike model and it'll tell you which GiPro is suitable.
Stormbringer
« Reply #7 on: 27 January 2020, 08:12:05 pm »
Got the Glpro 2 .
It has a touch pad and Shift warning as well as some other features.
All fitted and works like a dream .
Johnnylad123
« Reply #8 on: 27 January 2020, 08:32:12 pm »
Yep just checked their site, X type G2 is the listed model for a Gen1.
CatalinU
« Reply #9 on: 15 March 2020, 06:17:23 am »
What's the part number for the healtech kit for the GEN1?
robbo
« Reply #10 on: 15 March 2020, 12:02:10 pm »
Have a look at the last post, and my last post. :)
CatalinU
« Reply #11 on: 16 March 2020, 05:48:59 am »
Was it a plug and play fitting?
robbo
« Reply #12 on: 16 March 2020, 08:11:08 am »
No, you have to identify some wiring under the right hand panel, so you'd need a multimeter and a needle to be able to pierce the insulation to test which lead is which. Somewhere on the forum someone took my in depth fitting info, and made it into an advice feature, but I can't remember who that was. The fitting instructions are quite clear. Maybe making a bracket to mount it on is the hardest job.
CatalinU
« Reply #13 on: 16 March 2020, 05:22:16 pm »
I was looking for a thread on how to fit a healtech gear indicator, couldn't fin one :(
robbo
« Reply #14 on: 16 March 2020, 06:34:35 pm »
Can't remember who I pm'd the info to, but just buy it the instructions are really straightforward. From memory there's one cable to splice under the right hand panel, a plug and play cable that fits between a snap connector, and then some power. If you take the screen off to fit it, you can make a bracket to fit the display above and between the speedo/rev counter.
agricola
« Reply #15 on: 17 March 2020, 12:40:32 pm »
Info from the Healtech website [size=78%] [/size]
CatalinU
« Reply #16 on: 17 March 2020, 05:20:16 pm »
I am such a noob. Couldn't finmd that one anywhere. THX a million for that, that's more then enough :rollin :rollin
robbo
« Reply #17 on: 17 March 2020, 05:54:52 pm »
I knew it was somewhere, thanks MrAgricola. CatalinaU, that will save you having to mess about with a needle and multi meter :) , unlike when I fitted mine :'( .
