Date: 26-03-26  Time: 18:11 pm
Author Topic: Model changes  (Read 2456 times)
dangerdre
Model changes
« on: 28 October 2019, 07:16:17 pm »
Does anyone know if there were slight model changes between the years 1998 and 2001? I'm after getting a used replacement cowl stay and the mounting for holding the clocks is at a much steeper angle than the original - so much so that the clocks foul the ignition switch and can't be fitted. It's a used part so could have obviously been bent but it doesn't appear to be the case.
Re: Model changes
« Reply #1 on: 28 October 2019, 07:49:39 pm »
Same Stay on all the boxeyes, only changed for the Foxeyes.
dangerdre
Re: Model changes
« Reply #2 on: 28 October 2019, 07:54:09 pm »
Hmm...is the foxeye completely different looking?
Re: Model changes
« Reply #3 on: 28 October 2019, 08:22:02 pm »
Mounting point on frame is the same. Post a picture of what you have and I can tell you.
dangerdre
Re: Model changes
« Reply #4 on: 28 October 2019, 08:27:02 pm »
The one I'm after getting is exactly the same as my original except for like I described - the mounting bracket for the clocks is at a much steeper angle so the clocks end up fouling the front of the ignition switch.
dangerdre
