Date: 11-10-26  Time: 22:24 pm
Author Topic: Help needed please  (Read 3217 times)
Stew53uk
Help needed please
« on: 12 October 2019, 06:27:21 pm »
hi i just fitted an undertray to my fzs1000 (04). The battery was disconnected & now the bike won’t start. It has a meta alarm/immobiliser fitted. It will turn over but it comes up with a 9 fault code on the Rev counter, can anyone help shed some light for me please, Tia.
Re: Help needed please
« Reply #1 on: 12 October 2019, 07:21:02 pm »
Do this first
Check fuse on alarm. If blown replace it and follow these instruction
If fuse is ok or you have replaced itTurn on the ignition, press the alarm activation button on the fob once. Alarm should beep.Turn off the ignition
Turn on the ignition, now try starting.
tex
« Reply #2 on: 12 October 2019, 07:26:48 pm »
that's the  tip up senser  or overturn senser,  it's behind the battery a little black box,  you might have disturbed it , if you had the battery of
