Date: 25-03-26  Time: 20:47 pm
Author Topic: CLUNK,CLUNK,CLUNK,CLUNK  (Read 9103 times)
TOM VR46
« on: 21 September 2019, 03:10:46 pm »
This is only way I can describe this. Any gear when applying throttle, all I can hear and slightly feel is CLUNK :rolleyes , CLUNK :rolleyes ,CLUNK !! :rolleyes :eek :rolleyes :rolleyes !. Clutch in and free wheel - no clunk.  The clunk is getting slowly louder, don't know how long it would last before Clunk goes to Crunch !!. When just sitting ticking over all is ok, just when you are moving creates the Clunk.
Any ideas on where to start looking welcome and will be big help. My problem too, is time, if this is strip engine, could be long fix.
Oh, if just sitting and first gear, front brake on, slowly let clutch out , will pull no problems with no Clunk, only when moving does the clunk start.
Peeved as it great day for run. :'( :'( .
Oh, 2001 FZS 600 with just over 64 thousand on clock.
celticbiker
Re: CLUNK,CLUNK,CLUNK,CLUNK
« Reply #1 on: 21 September 2019, 04:16:54 pm »
That'd be the front sprocket wear. The teeth have hooked and the chain clunks as it drops into the teeth. Would always recommend replacing both sprockets and the chain at the same time.
You can alleviate the problem by careful adjustment of the chain but replacement is the right way to go.
Fwiw I recommend and use myself, DID HD  gold X-ring chain and renthal sprockets. Keep away from those kits with JT sprockets in, they wear too quickly and take the chain with them. I get around 40k-45k from my chain and sprockets.
« Reply #2 on: 21 September 2019, 05:04:35 pm »
 :agree most likely worn front sprocket/chain.
No pressure on it when clutch pulled in.
I find changing the front sprocket every 10 to 12000 miles helps the life of the my chains.Remember front sprocket wears 3 times faster than the rear
TOM VR46
« Reply #3 on: 21 September 2019, 05:23:06 pm »
Thanks for replies. Had been thinking of new chain and sprockets. I changed the front sprocket last year and took it down to 15th and also changed the sprocket nut too. Ive no idea what age chain is , as I never got told that when I bought it. I do keep it well lubed as bike is use the bike weekly. Will have a look tomorrow and see how chain is running over front sprocket. Hope that's the solution. Thanks again.
« Reply #4 on: 21 September 2019, 06:12:39 pm »
Put the bike on the centre stand and try and pull the chain off the rear sprocket, anymore than 5mm and your chain is heading for replacement. See file attached
« Reply #5 on: 21 September 2019, 07:39:55 pm »
If it's the sprocket or sticking chain links then you must be feeling it through your left footrest?
« Reply #6 on: 21 September 2019, 09:48:48 pm »
I had a chain which broke one of its link plates on the inside of the run. That gave a regular clunk and it took me ages to find the cause because it was so hard to see the crack. Must have done a thousand more miles before I spotted it… amazed the thing didn’t let go.
TOM VR46
« Reply #7 on: 21 September 2019, 10:30:20 pm »
Well I tried to reply but something went wrong. I had a look and took pic of sprocket. Will try and attach before I go on.
Trebus
« Reply #8 on: 21 September 2019, 10:44:20 pm »
That looks quite hooked and needs to be replaced.
TOM VR46
« Reply #9 on: 21 September 2019, 10:49:43 pm »
oops :rolleyes something went wrong again. Ive heard about pulling chain at the rear sprocket but never tried it. Will give that a try tomorrow and see what happens. Ive put old sprocket on again and the chain seemed to run over it a bit smoother. Again see how that goes tomorrow.
And yep you can feel it through the foot rest. The louder the clunk the more you can feel it. It starts from 1st and through to 6th. Most noticeable at low speeds in higher gear.
Ive also had a wee look and ive had bike about 2 years and done around 10000 miles in that time. So maybe time for new chain and sprockets, as I have no idea when they were last changed.
Will give it a wee test run tomorrow to see what the difference is in the sprockets.
Thanks again for replies  :) and I hope this one posts. Will let you know what happens tomorrow.
« Reply #10 on: 22 September 2019, 01:12:01 am »
If you're feeling it through the footpeg it's most likely a sticky chain link.
Sprocket is a bit worn, but not that bad.
Look at the lower level of the chain, a sticky link will be at an angle, rather than horizontal.
« Reply #11 on: 22 September 2019, 11:13:00 am »
That sprocket is focced.
« Reply #12 on: 22 September 2019, 12:05:27 pm »
All needs changing whatever way you look at it  :lol
TOM VR46
« Reply #13 on: 22 September 2019, 03:11:22 pm »
 :) Well as I said I put old sprocket on last night and,,,,, no Clunk today  :) . But the old sprocket has signs of hooking on it too.
Was a bit worried as it started to clunk quickly. But as I said was thinking of changing chain and sprockets. Going to be costly month as need new rear tyre, front brake is close to edge, and now chain and sprockets. Wee bit of overtime needed.
Thanks for pointing straight to sprocket.  ;) . Help well appreciated.
Oh, and tried pulling chain at rear sprocket. And it does pull out :o , probably about 3mm without much effort.
Well time for coffee and thanks again.
« Reply #14 on: 22 September 2019, 04:33:23 pm »
I had the same symptoms and the sprockets were not in bad shape but it was the chain that had a tight spot. I changed both sprockets anyway along with the chain,its its great not having the clunk after putting up with it for too long.
« Reply #15 on: 22 September 2019, 06:52:42 pm »
It is best to set the chain to the tightest position half way along the swinging arm, this way you are pulling the most worn section of the chain from the sprocket.
In any case a new set of sprockets and chain are needed.
TOM VR46
« Reply #16 on: 22 September 2019, 09:35:09 pm »
Yep , new chain and sprockets on shopping list. Had a look today for old riveting tool I once had, cant find it :\ :\ , so that could be on list too. Was nice not hearing and feeling that noise today. Finished work at 5am on Sat morning and was wondering if I was going to make it home. And yep that's the way I adjust the chain, trying to find tightest spot first. And on paddock stand. Tried it once as it say somewhere in manual to have the bike on side stand,,,, no way could I figure out how you could set the chain this way. :rolleyes :rolleyes .
« Reply #17 on: 22 September 2019, 09:41:15 pm »
Easiest way to adjust the chain on the Fzs600 is to find the tight spot and at a point under the end of the rubber swinging arm protector, push the chain up and it should just touch the rubber, if it doesn't it's  to tight.
redmandan
« Reply #18 on: 22 September 2019, 10:38:04 pm »
You do that on the side stand or centre stand?
« Reply #19 on: 22 September 2019, 10:39:47 pm »
Centre stand
« Reply #20 on: 22 September 2019, 10:45:12 pm »
My change is all here - be warned 6 pages http://foc-u.co.uk/index.php/topic,25205.125.html
Middy2000
« Reply #21 on: 23 September 2019, 01:23:05 pm »
I'm now thinking this is the issue I have with my bike.  Only when cold does it do it.  First couple of junctions I get the clunk as I set off.  Don't notice it in any other gear but then the noise maybe drowns it out.
She's a 2001 and just clocked up 10,000 miles.  Would the front sprocket be worn this quick?
« Reply #22 on: 23 September 2019, 04:10:15 pm »
Short answer, Yes.
Middy2000
« Reply #23 on: 23 September 2019, 07:51:01 pm »
Precise and to the point. Like it.
What's the longer term diagnosis of running it like this. To be fair iit' been like it 6 months already.
Will it last a few more miles until I lay her up over winter and then I'll fit new chain and sprocket? I take it I'm risking the chain snagging and totally screwing the sprocket?
« Reply #24 on: 23 September 2019, 08:13:55 pm »
Or if it is because of a badly seised couple of links then you could be risking a snapped chain. I tried to ignore mine for as long as I could but couldn't really relax and enjoy my rides. If you are only slow commuting then you may decide to take a risk.
