Date: 10-05-26  Time: 09:37 am
Author Topic: Rear LED light bar issue  (Read 2252 times)
Riggerlee88
« on: 24 August 2019, 02:23:03 pm »
Hoping for someone’s help. I have an Integrated LED light bar with indicators. The light works fine when the bike is on tick over what seems to be the issue is after a ride the light bar seems to malfunction (flashes non stop) until I turn off the bike and restart. On my Koso dash I have a  volt meter which reads when riding 14.2 V is this too high? Also if I take the rpm up to around 10k+ the Koso Rev gauge also plays up until I restart the bike. So my question is should the bike when riding generate 14.2v and or is my regulator rectifier faulty. To confirm the bike is full LED conversion and a LED indicator relay installed to eradicate the fast pulse.
Any help would be greatly appreciated.
limax2
Re: Rear LED light bar issue
« Reply #1 on: 26 August 2019, 11:04:12 am »
14.2 volts on you dash mounted gauge sounds fine. I think mine shows about 14.5 volts when I've measured it at the battery with a few revs on the engine. The Yamaha manual quotes a no load regulated voltage of 14.1 to 14.9.
I have zero knowledge on LED stuff.
Riggerlee88
« Reply #2 on: 26 August 2019, 01:43:31 pm »
Thank you for your response it’s much appreciated glad to know that’s the acceptable range which helps me eradicate the regulator rectifier 👍🏻
BBROWN1664
« Reply #3 on: 26 August 2019, 09:00:42 pm »
let us know how you get on with the MOT using the lightbar as they are clamping down on the distance between indicators now.
Riggerlee88
« Reply #4 on: 27 August 2019, 06:21:19 am »
I managed to get it through in April without them mentioning anything, the current light bar I am using converts half of the bar into the indicator as oppose to just the end portions (much safer) but technically I have zero separation between left and right I suppose it is pot luck
