Date: 09-05-26  Time: 08:33 am
Author Topic: Rear brake rebuild  (Read 2733 times)
Slippy
Rear brake rebuild
« on: 15 August 2019, 06:53:08 pm »
Have a fzs600 2002. Bought some rear caliper break seals of wemoto. The piston seal fitted like a glove but the dust seal was a struggle. Looks to big but does fit with a bit of faffing.
Trying to put the piston back into the caliper and it won't budge past the the dust seal anyone got advice ?
Cheers
Trebus
Re: Rear brake rebuild
« Reply #1 on: 15 August 2019, 08:05:35 pm »
Have you fully scraped out any corrosion that’s in the groove. Sometimes hard to see but can make the difference. I have known aftermarket dust seals to be a bit hit and miss, sometimes you can get away with reusing the old one. In a bind I’ve had them where they’ve expanded and cut a small section out, then glue back together. Not ideal but can work!
« Reply #2 on: 16 August 2019, 05:46:39 am »
Use plenty of Red Rubber Grease.
Slippy
« Reply #3 on: 16 August 2019, 08:47:45 am »
I scraped out all the corrosion, was like white dust. They really seem to just be around 2-3mm to big. The old ones are in the bin. Might try cutting and gluing.
bandit
« Reply #4 on: 16 August 2019, 03:56:35 pm »
Unfortunately this has cropped up before about rear brake seals from Wemoto .
« Reply #5 on: 16 August 2019, 06:10:45 pm »
Buy them here instead, great to deal with and they specialise in brakes, both car and bike.
 https://powerhouse.uk/content/motorcycle-brakes/motorcycle-brake-caliper-seal-kits.php
« Reply #6 on: 18 August 2019, 05:53:04 pm »
Looking at their site they can do our rear brake rebuild for £45. Sounds good to me -send it in and let them do the whole thing and deal with any seized bits.
Slippy
« Reply #7 on: 19 August 2019, 11:59:56 am »
Got the brake seal kit from power house on order. And the brakes are fully taken apart and cleaned so they are ready to go back together.
bandit
« Reply #8 on: 19 August 2019, 01:53:54 pm »
Slippy, if you still have the Wemoto dust seals can you let us know if they're larger/difference between them & the Powerhouse ones when they arrive please.
