Date: 07-05-26  Time: 17:28 pm
Author Topic: rear shock  (Read 7748 times)
ddtwelve
rear shock
« on: 11 April 2012, 03:27:01 pm »
can the rear shock spring be replaced or do i have to have a new shock fitted as i dont like the 2-3 inch drop when are lass jumps on even thou its on full preload
Re: rear shock
« Reply #1 on: 11 April 2012, 07:24:23 pm »
Providing the rear suspension isn't bottoming out when you hit bumps you might find some different dogbones (a.k.a a jack-up kit) would suit. Adjustable ones would let you set it up if you do a mix of solo/two-up riding.
Alternatively, suggest she loses some weight. :lol
ddtwelve
Re: rear shock
« Reply #2 on: 11 April 2012, 07:51:02 pm »
MMMM which type will work with the fz6 bike ??
Re: rear shock
« Reply #3 on: 11 April 2012, 08:26:48 pm »
Must admit I assumed they'd be as readily available as they are for the FZS600, a quick Google has shown that was a mistake. These guys might help though:
www.projection-components.co.uk/
mcyoungy
Re: rear shock
« Reply #4 on: 11 April 2012, 08:33:29 pm »
The FZ6 doesn't have dogbones. It uses a shock directly connected between the swingarm and frame, cantilever stylee.
You would need to get a new spring fitted. So to answer your question, yes it can be changed. It's a fairly easy DIY job but you need something to compress the spring - a motorcycle shock spring compressor is ideal although you can use ratchet straps.
ddtwelve
Re: rear shock
« Reply #5 on: 11 April 2012, 09:44:09 pm »
cheers mcwobbly
bwizz
Re: rear shock
« Reply #6 on: 11 April 2012, 10:12:46 pm »
You can also use big jubilee clips
ddtwelve
Re: rear shock
« Reply #7 on: 12 April 2012, 07:46:51 am »
next question is what size is the spring as theres a place near york that sells springs for £56 is it 6 inch height with 2.5 inch diameter?
