Date: 02-05-26  Time: 23:07 pm
Author Topic: Deklevic headers and no exup  (Read 7658 times)
goldfazer
« on: 30 July 2019, 05:12:05 pm »
OK, the saga of the exup continues. I won't bore you with the details, but the selling dealer is saying that as it has a Deklevic an already, it'll run fine with Delklevic headers with no exup. My workshop says that's crap. What say you lot?
goldfazer
Re: Deklevic headers and no exup
« Reply #1 on: 30 July 2019, 06:28:49 pm »
FZS1000, 2005
Dudeofrude
« Reply #2 on: 30 July 2019, 06:32:01 pm »
It wont run 'fine' without the exup unless its tuned to do so.
My understanding with the gen 1 is that the exup helps with low down power by creating back pressure at low rpms.
With it removed and no change to the fueling I believe it would become rough and a bit gutless down low.
I'm sure it would be rideable but I doubt it would be an improvement
goldfazer
« Reply #3 on: 30 July 2019, 10:10:49 pm »
Cheers. I'm heading for the 'pay for it myself and take 'em to the small claims court' route I think.
Falcon 269
« Reply #4 on: 31 July 2019, 06:11:29 am »
It will run OK with the Delkevic headers but not as it should and no amount of tuning will fix that.  The only aftermarket headers designed and proven to retain the scavenging characteristics of the OE EXUP system were made by Muzzy in the USA.  These are no longer in production.  All the others available, including Akrapovic, soften the power delivery below 4k rpm and in the worst cases, create a flatspot in that region which can't be tuned out via carb mods or anything else.
Technically, I think you'd have a hard time getting a satisfactory outcome through legal action because the bike does run 'OK' with the headers fitted when you bought it.  Good luck, though.
WayneUK
« Reply #5 on: 31 July 2019, 11:33:13 am »
i had same problem with my 2003 with a beowulf fitted,
the guys at the dealers workshop said it doesnt need it with having that can on and said they can put a eliminator to stop the tach error,but didnt make any difference, but when the main mechanic came back from being off ill, he rang me and said it needs the exup sorting its not right without it,he had it for a week, he put new cables and valve in, as he said the one in was completely siezed, and now its been done what a difference it makes,I noticed the difference in sound soon as he started it up and now runs much smoother at low and high speed.
goldfazer
« Reply #6 on: 31 July 2019, 11:58:58 am »
I'm not sure about that - it has a fault and as I asked them if the exup was OK when I bought it and was told yes, I think I have a decent case. The Mrs is on the case anyway - she's a terrier.....
Falcon 269
« Reply #7 on: 31 July 2019, 05:04:29 pm »
Fair enough ... if they didn't tell you the EXUP was effectively missing and the reason why, I agree that they withheld information pertinent to the sale.  Have at 'em! :)
b1k3rdude
« Reply #8 on: 31 July 2019, 08:50:29 pm »
Quote
Er no, what this cunt of a dealer has done is commit fraud! and yet still persist with the fucking outright audacity.
Its far worse than that Mike and what they have done carries some very serious penalties for the dealer concerned. The Consumer Rights Act 2015 is very clear -
  • The goods must be fit for purpose (i.e the bike must be roadworthy and ride-able unless described otherwise)
  • The goods must match the description given at the time of purchase
They did not inform goldfazer that non-standard headers were fitted, they instead deliberately mislead him - this breaches both of the above rules so Gold you have several options -
  • If you bought a product less than 30 days ago is unfit for purpose, faulty or not as described, you have the right to return the product and receive a full refund.
  • If a fault is discovered after the first 30 days but within 6 months of the date of purchase, the fault is presumed to have been there at purchase. It is for the retailer to prove that this was not the case, and not for you to try to prove that it was -
  • You will be entitled to a full refund if repair or replacement is not possible, or is unsuccessful. You have to give the dealership a reasonable opportunity to try to fix the fault. However if they have tried to repair the vehicle more than once unsuccessfully, this requirement will have been fulfilled.
If it has been over 30 days since you purchased the product, you can choose for the retailer to either:
  • Repair the product, or Replace the product.
  • The retailer may however refuse if they can show that your choice is disproportionately expensive compared to the alternative - this would be very hard for them because I have found a complete exhaust system on ebay with the exup for £250 - but common sense you check with the seller that the exup is not seized and moving freely (turning with bare ringers freely).
  • If a fault is discovered over 6 months after the date of purchase, it will be for you to prove that the fault was there at the time of purchase. It is likely that an expert report would be needed to prove this - any yamaha dealer can write a letter stating what exhaust system the FZS1000 is supposed to come with.
Gold what is the name of this dealer so we can all avoid these cunts! as I would happy ride over there on my FZS1000 and visit them with you and your wife to lay the fucking law down and show them what should be fitted to said bike.
goldfazer
« Reply #9 on: 01 August 2019, 10:06:40 am »
Just to clarify, it has the std headers and a stuck exup valve (well, had as it's been removed :) ).
goldfazer
« Reply #10 on: 01 August 2019, 10:07:25 am »
I'll name the dealer when it's sorted. But it's a Honda dealer in Manchester
VNA - BMW Wank
« Reply #11 on: 01 August 2019, 05:54:02 pm »
Just in case anybody is looking for headers.......
I think holeshot headers are still available.  Ceramic coated steel rather than stainless though.  But properly researched rather than thrown together.
But wouldn't think they would be much use with standard carbs.Probably OK with Ivans kit fitted?But as Mike says will still be a touch softer than EXUP below 4000rpm.
Good luck with getting a result here.
goldfazer
« Reply #12 on: 03 August 2019, 10:48:49 am »
Update, got a used exup from ebay for £154. The dealer are basically telling me to get stuffed so I'll be filling in the small claims form shortly :)
goldfazer
« Reply #13 on: 07 August 2019, 06:39:41 pm »
Finally got her back. £154 for used exup (ebay) and £175 labour. Could have been much worse! Will now fire up the small claims court
b1k3rdude
« Reply #14 on: 07 August 2019, 09:08:05 pm »
£175 labour.
Er wtf were your local shop doing that it took 3-4 hours to swap an exup valve..?
ogri48
« Reply #15 on: 07 August 2019, 10:27:31 pm »
glad you got it sorted dude.  :)
goldfazer
« Reply #16 on: 08 August 2019, 09:43:57 am »
£175 labour.
2 hrs to remove (inc. headers), drill and thread the stuck bolts. 1 hr to replace!
goldfazer
« Reply #17 on: 08 August 2019, 09:46:18 am »
Actually, a bit less than 3 hrs. It was £175 inc vat and £55/hr + vat
b1k3rdude
« Reply #18 on: 09 August 2019, 12:30:38 am »
Ah yes, that old chestnut. I look forward to hearing how the dealer that sold bike pays for all this work.
